Fast
- Sep 25, 2018
How much does that costYes bearing assy!![]()
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
I’m doing every bearing in my sled. And I mean EVERY. I do agree with the two inside the chaincase being less likely to fail. But @7200 miles it’s time IMO. Maybe 10 k would be more like the number for the two inside chaincase. But it’s coming all apart for drive bearing and possibly new drive shaft.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Once you get close to 10,000km it is time or getting very close to doing all 4 drive bearings (chaincase and clutch side)
MS
MS
mooser17
- Jan 10, 2017
- Muskoka
- Sidewinder ltx le
It's a big job too just do clutch side, for the cost of the bearings just do all four. You will have piece of mind for many miles ahead in my opinionOnce you get close to 10,000km it is time or getting very close to doing all 4 drive bearings (chaincase and clutch side)
MS
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Y
For sure - if you are replacing clutch side you pretty much have to open the chain case up to allow the jack shaft out. At that point its do them all or nothing.
MS
MS
lilrez
- Feb 7, 2016
- Near Ottawa
klr650r
- Jan 26, 2018
- New Brunswick
- 2018 Yamaha Sidewinder R-TX LE 50th
This is my opinion, but check it every start of season or every 4000 miles, which ever comes first.
It's going to be relatively easy to check. loosen the track, take out the three caliper bolts and you'll know instantly if the bearing turned on the shaft or if it's seized.
lilrez
- Feb 7, 2016
- Near Ottawa
lilrez
- Feb 7, 2016
- Near Ottawa
Thing is bearing is not siezed and rolls smoothly, so even if i checked it at 5000km instead of 10000km what differnce would it make.
You might have saved the driveshaft. Wow that got hot!Thing is bearing is not siezed and rolls smoothly, so even if i checked it at 5000km instead of 10000km what differnce would it make.
lilrez
- Feb 7, 2016
- Near Ottawa
Im still trying to understmad how would i have saved the driveshaft? The oem bearing is not a pressed fit and can spin on the shaft. It has to or we would never be able to pull the shaft out. The oem bearing as found rotates freely. I dont think replacing the bearing at 5000 would have saved the driveshaft..maybe at best extend a season.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Only way is to pull the bearing as soon as possible dimple the #*$&@ out of the driveshaft , possibly a little green bearing retainer and re install. Personaly I dimple only. Never had an issue .
lilrez
- Feb 7, 2016
- Near Ottawa
Excellent. How many miles you at now with this mod?Only way is to pull the bearing as soon as possible dimple the #*$&@ out of the driveshaft , possibly a little green bearing retainer and re install. Personaly I dimple only. Never had an issue .
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
6000 on one sled and 7000 on another.
DIwarrior
- Oct 22, 2003
- Drummond Island MI
- 2025 SRX LE #473
2025 SW XTX LE
2025 SW LTX GT
2001 SRX
1968 Ski-Doo
- Drummond Island, MI
- Nope
6,000 miles, my chaincase bearing failed, spun on the drive axle, had to replace the drive axle, all bearings, chain and tensioner. All covered under yes warranty. Discovered the damage while doing a track replacement, Ice Attack 1.22 was tearing off lugs, not covered under warranty.
- 6K
- 9K
