3500 miles driveshaft and bearing smoked
Here is the bearing I used. I decided to use what I think is a better quality bearing since I had the thing apart. Not sure where the low quality bearings that Cat is using come from. Most of the grease was out of the stock bearing.
This might be a dumb question but what does using the peen and O-ring method mean? And can this be done with the dry shaft in the Sled ?
Post #73 shows the O ring idea. Simple and hopefully effective. I may pull this thing apart again mid-season and verify everything is working and go with the set screw idea if that proves to work better.
My wife bought me a really nice Christmas present. Maybe she really loves me or just wants me to stay in the garage....:)
BD Xtreme shaft +superlight disc brake
The shaft is 1.17715 and the NACHI bearing i have on hand is 1.772. Seems to be a perfect fit
youtube rockerdan video # 5,6,7 and the O ring is from Stain who posted just before you.
Now on to a little more input about what to use to bond the race to the shaft. My uncle works on huge Caterpillar machinery for all his life over 40 years. Asked for his input while he was at my house for Christmas, He explained to me in detail that rocker dans way of pinning the shaft is the way to do it. (pinning is basically hitting the area of the driveshaft in the spot the race of bearing rides with a sharp hardened chisel that will raise the metal around it, making it larger and also providing a area for the bonding agent to lock into) with that being said and reviewing the videos of rocker dan on youtube, he suggested more chisel spots all the way around shaft using a air chisel. This will keep the bearing centered with a driveshaft that has more ware. He also stated that he/they use this method regularly on equipment do to dirt on shafts like bulldozers. YA YA SOOO.. Last thing is he suggest using Loc-tit 620 and pinning it as much as possible so the 620 bearing mount has something to bond to. - 2 smooth serfises are hard to bond. 620 will almost be like welding on the race.
The second pic is not a bearing cup it’s a second seal and that bend in it is for water to get out. It’s not damaged.
My friend sled it’s nice and flat on the inside of the body ,mine only touches the body at the bolt holes the rest of the cup is swelled out from the body Hard to see in the picture but zoom in
Oh got ya. Flatten it out. Its just sheetmetal. That comes from someone not having it flat at assembly. It really just keeps ice chunks and junk from taking out the actual bearing seal.
Right, mine was not flat from the factory either. My replacement is though as I assembled it perfectly and properly. :-o
It's sheet aluminium and very soft and bendable too.
Unfortunately DON t BY THIS SHAFT:o|:mad:#$%&*:moon:
I will start a post tonight :drink::jack:
Looking into this for the summer. Is there enough room to drill and tap a set screw with the drive shaft in the sled?
Not sure,maybe we had mine out,and it was still a bear to tap through,you need a very sharp and new tap.
