- Apr 14, 2003
- Hessel, Michigan
Beerman, here is my setup:
Orange primary spring with 2 glide washers (one each end)
58g base weight
Tip 7/16 steel bolt with 2 thick washers
Mid 3/8 aluminum bolt with 1 thin washer
Heel 3/4 set screw
Secondary
Orange spring set 3-3 with 33/35 helix
9,000-9,050 rpm
Gates carbon fiber belt in 8jp length (40C4313)
XTX 141, 1.6 Cobra track, no studs and 21/41 gearing. My clutches are machined for more overdrive.
58g base weight
Heel 3/4 set screw
Secondary
9,000-9,050 rpm
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Evo Stage 4? How much boost?Beerman, here is my setup:
58g base weight
Heel 3/4 set screw
Secondary
9,000-9,050 rpm
Thanks!
**sj**
14.5-14.9ish texted you!Evo Stage 4? How much boost?
Thanks!
**sj**
I tried it last year so if I remember right it struggled in the mid range with rpm and took a little longer to reach peak rpms. The 35/39 was snappier and better cruising rpm and better mpg. The 38 was a STM and my 35/39 is a Dalton also.
with what weight profile...flat or curved?
- Apr 14, 2003
- Hessel, Michigan
Thanks!
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
Shagman, NOS-PRO, arm, sj - If I haven't said it recently, I'll say it again now - THANK YOU for all the great advice you guys post and all your testing.
- Apr 14, 2003
- Hessel, Michigan
Thanks Beerman
**sj**
shag and nos pro are fantastic guys and an asset to the site...and the sport for that matter..
- Apr 14, 2003
- Hessel, Michigan
Thank you SJ
shagman
Vendor
- Feb 18, 2014
- Cedarville Michigan
- 2017 Sidewinder BTX LE
2014 SR Viper XTX SE (Sold)
Thanks guys. Really appreciate it.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
X 2!
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
"arm" was an auto-correct for krm!Shagman, NOS-PRO, arm, sj - If I haven't said it recently, I'll say it again now - THANK YOU for all the great advice you guys post and all your testing.
Jafo1970
x3
