hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Unless you have hardened those jaws since I have had you proto types, it will be damaged. Have you made a change?
The tapered wedge with the threads is a harder material. If we make the jaws a harder material then the tool has even more internal resistance to overcome.
I did a test fit and then removed it and did not see any issue.
Well I am only asking because I destroyer that pro-type at 80ft-lbs enough that it would not work a 2nd time. Thanks
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
BOP is famous. Reading french FCMQ online mag and they mentioned BOP.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
BOP puts out sooo many great innovative products for our Yamahas!
He is always testing and adding more each season!
I’ve been using BOP for years, but my dealer mentioned some of his product fixes last year. I said yep, he has been at it for a while now, and he is good at what he does!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
O and he’s a vendor on TY! So this means he is tuned in and on THIS SITE answering questions.
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I have him on Speed Dial under GOD
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yep do the same , been using the same driveshaft since 2017 , moved it to my 2019 as I run 10 tooth 2.52 drivers. Have roughly 10000 miles on it now. Will inspect again shortly but I'm sure it's good for another season or two yet.3499 miles on my 2018, and the prick punches from last year are still visible no signs of spinning on the axle. Go figger...lol.
I made 10000 on my first axle using same process every season. Then couple seasons ago she spun on me. Maybe dirt in bearing or I was running track looser? But it wore pretty good.Yep do the same , been using the same driveshaft since 2017 , moved it to my 2019 as I run 10 tooth 2.52 drivers. Have roughly 10000 miles on it now. Will inspect again shortly but I'm sure it's good for another season or two yet.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
I had grease everywhere,as I needle greased it way too much...lol... As I have on all the yamaha jackshaft and axle bearings over the years..never had a failure, bogies too...they eventually do get sloppy but never sieze and fall off like I see on the trail every year...I have a nice collection of peoples bogies!!I made 10000 on my first axle using same process every season. Then couple seasons ago she spun on me. Maybe dirt in bearing or I was running track looser? But it wore pretty good.
The first year I took the SW axle bearing off, there was a lot of rust. This year it looked great once I cleaned up the grease mess. None gets on the brake rotor so I dont care...The bearing felt like brand new. Guess time will tell.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
My shaft survived the winter this time around using the BOP wedge. I also peened the shaft and used bearing retainer.
- 9K
- 7K
