no1b4me
- Dec 31, 2016
- 2019 ZR9000 Ltd iACT
Very functional location, I emailed them to ask if they had a bracket to accommodate the 2 hole Duraflex scratcher mount system
This is the part you are looking for.... Just do a net search.
StraightlinePerforma 185-106 ICE SCRATCHER A-ARM MOUNTS
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
They work great had for two years and you can backup.For this year I switched out my ice scratchers from the tunnel ones to the BRP rail ice scratchers. When I took my skid out this year, I noticed the bolt holes on the hanger for the upper iddler wheels were egged out a bit, which concerned me, so I am going a different route this year to see how these work. I only had to drill one additional hole which was nice.
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
They offer only the single hole A Arm to attach scratcher.The barn of parts offer the 2 hole bracket for scratcher attachment
SledFreak
- Feb 7, 2005
- Ontario. Canada
How many miles do you get out of those tips?.... Why have things tangling from the skid or tunnel until you use it?
These SLP control arm scratchers are the Catz Azz.... Why have BRP crap hanging underneath, they wear quickly, rust and risky getting hung up in the track.... Fuzz that crap... Go with full stainless steel cable with replaceable Woody carbide tips.... Also they fold over when reversing and won't break like the BS BRP ones, .... They also install in seconds, no tools required .... When not in use, carry them in your trunk bag or make a storage clip under the hood.
Turboflash
- Mar 18, 2019
- Southern MN
I have been using the Duraflex scratcher for several years. Work perfect in reverse. No need to hook them up when backing up.You are correct, you must lift and hook them when you back up.
https://www.amazon.com/DURA-FLEX-ICE-SCRATCHERS-KIT/dp/B008YFSH44
rtx moose
- Jul 31, 2014
- WATERTOWN,MN
what happened?did the cable frayNever had great luck with them.. mine all fell a part.
Yep, then ends fall off. I gave up because of the price and they dont warranty the product.
Hoosiersnow
- May 19, 2015
- Indiana
- 18 cat 600 137
Seems like there are a lot of scratcher options and no clear best choice.
cjr
- Jan 28, 2018
- Old Forge
- 2018 Sidewinder 2021 sidewinder xtx le 146
The picture I posted is from my new sled they are from the factory don’t know much about them
- Feb 13, 2017
- Amston,CT
These seem to be efficient and only $65 a pair
I have these on one of my sleds. I really like them, I think they work really well.
Snowman871
- Feb 9, 2010
- Woodville, WI
- 2024 Polaris Assault 850
I had a similar experience with the cable style scratchers mounted to my skid - lost the whole tip on one side in less than 100 miles of trail riding... I live in an area where it is common to cross rail road tracks, guessing that it hooked and pulled the end right off. Only spring loaded stuff for me moving forward...
Exactly!!
I had the cable style scratchers mounted to the skis and the spindles were getting all chipped up from the debris the scratchers would throw at them.
I also had them hanging from the sway bar link and I could hear them pounding the bottom of the sled.. hated it.
