- Nov 29, 2009
- sabattus, maine
I think a couple videos like above done on a chassis dyno would be interesting. One done with no load and one done under load to see just how much chassis flex there is under power.
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
And
That was going to be my next point... Theory: Loosen the spars... Use ratchet straps and pull into position... Re tighten spars
Fleecer
- Jun 13, 2014
- 2019 SRX
Has anybody with a belt burner and stock clutches done this and found any discrepancies??
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
I have done this on my viper turbo. I got 1mm behind the clutch to make the belt go straight I am on 8dn belt
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Blown 6 belts in about 250 miles. Tried adding shims, removing shims, breaking in belts, not breaking in belts, put all clutching back to stock and blew another. Pretty frustrating, dropping it off at the dealer this morning.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Wow that sucks! Snapping belts clean or shredding from heat?
Soupy
- Jan 10, 2017
- West Michigan
Shredding. Clutches way too hot to touch.Wow that sucks! Snapping belts clean or shredding from heat?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Soupy did you do the eyeball test and check Center to Center and parallel?
How did it run? Bogging?
Soupy
- Jan 10, 2017
- West Michigan
Yes eyeball, straightedges, pulled clutch cover twice, micrometers, calipers, indicators, etc.Soupy did you do the eyeball test and check Center to Center and parallel?
Runs great, no bogging. I don't think i really have the proper tools for c to c or parallel measurements.
I appreciate your help, feel like dealer was my last resort. Been blowing belts since brand new. I welcome any other help and suggestions.
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
- 17 LTXse Sidewinder
"Soupy, post: 1402696, member: 29748"]Yes eyeball, straightedges, pulled clutch cover twice, micrometers, calipers, indicators, etc.
I appreciate your help, feel like dealer was my last resort. Been blowing belts since brand new. I welcome any other help and suggestions.[/QUOTE]
If your keeping the stock clutches? Tell the dealer throw away the Primary and buy/trade a Apex primary, the button slides and towers are twice the size of the Sidewinder... that clutch IMO is inconsistent/inefficient and plain doesn't work! I put the Apex on before my STM's and never broke a belt ..... Look at the pic, the Winder spider arm is bigger and half the size button now? That's like putting a 600 lb man on a little kid snow saucer shove em down the hill he ain't going nowhere fast...They beefed up the winder clutch in areas but looking at them it didn't help things IMO made a great clutch that belongs in a scrap metal pile.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
ummmmmmmm no don't do that
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
What checks? Oh dam they are gone!
Soupy
- Jan 10, 2017
- West Michigan
Hey Super, any update on this after you've hopefully put some miles on it?
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
Yeah for me it made a big difference "for mine" 700mi no belt breaks or dust on a 8dn, clutch temps are just warm. I couldnt get 200mi on any belt or clutch.
SuperTurbo
- Mar 20, 2004
- Amherst, Ohio
A member asked if he could send a video to me to view and what I thought. His was slightly off and was actually to STM specs 2.09? Go figure
- 12K
- 7K
- 6K
