![](/styles/TYLifeMember.gif)
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
I was running TD Powertrail Stock Muffler tune.
I had Dalton QAY's with no weight in them trying to get the RPM's over 9000 then add weight to bring it down. I believe i'm not running full power. Pulls real good, but i should be over-revving with no weight in the arms. That's another day & another story.
It's going to be an OCD March Madness kids!
![](/styles/vip.gif)
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
How many miles on clutch? Rollers?
Rollers stock YAM?
grrrrr
Rollers stock YAM?
grrrrr
- Apr 14, 2003
- Hessel, Michigan
Lots of clutch dilemas this year!!
As I mentioned this well over a year ago....the clutches that started to come apart back then. Now, more and more miles getting put on is showing the true colors of this clutch, and it's going to truly hurt or kill someone. Mark my words.
It sucks that Yamaha isn't doing a thing about it. And yes, I have contacted everyone I can at Yamaha and they just keep blowing me off saying they do not have an issue.
@stevewithOCD Did you let your dealer know? If you didn't, could you please do so?
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
I did read Steve’s other thread which forced me to edit my last comment. Didn’t the self locking nut come unthreaded to make the roller pin fall out?
Correct me if I’m wrong......
- Apr 14, 2003
- Hessel, Michigan
You are correct
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
The funny part about all this clutch talk is the Yamaha clutch was one of the reasons I didn't want a Cat. I wanted a Yamaha clutch because I had them before and they were great. I didn't want the team on the Cat because of all the belt blowing and other issues with them. Now it turns out the Yamahas are the ones to stay away from.
number1kyster
How many miles on that clutch?
Do we need to start replacing rollers, bushings, bolts, and nuts every fall as preventative maintenance?
Snowaddict
- Feb 28, 2005
- Menasha, WI
- '17 Sidewinder LTX-LE
- mstahl88
DittoThe funny part about all this clutch talk is the Yamaha clutch was one of the reasons I didn't want a Cat. I wanted a Yamaha clutch because I had them before and they were great. I didn't want the team on the Cat because of all the belt blowing and other issues with them. Now it turns out the Yamahas are the ones to stay away from.
- Apr 14, 2003
- Hessel, Michigan
Yes, I couldn't agree more with what you are saying, but this Sidewinder clutch is a pile....shouldn't even be compared to the other Yamaha clutches prior to the SW
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
There is no doubt that Yamaha could have beefed this clutch up better, maybe a 4 or 6 arm clutch would have evened out things on big tunes.
But most of the explosions seems to be op error or parts worn beyond their limits. From everything I have seen the big tunes 270 and up is where you need to really keep tabs on the wear. Not as drastic stock or low/medium tunes.
XP123
- Dec 25, 2016
- Chautauqua NY
So they release their most powerful sled ever and put the worse clutch they can come up with on it? What sense does any of that make?Yes, I couldn't agree more with what you are saying, but this Sidewinder clutch is a pile....shouldn't even be compared to the other Yamaha clutches prior to the SW
- Apr 14, 2003
- Hessel, Michigan
Absolutely none, no sense why they changed it.
Best part was when some TY'ers were allowed to see the new Sidewinders in person at the Yamaha Pleasant Prairie location, the Sidewinders that had test time on them had old primary clutches on them and the ones with zero miles had the new Sidewinder clutch. Still trying to figure that one out
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Sounds like they tried to lighten the clutch up a bit, maybe to reduce the feel of turbo lag even more.
swampcat
Thats the NEW corporate mentality. Raise the price, LOWER the quality.So they release their most powerful sled ever and put the worse clutch they can come up with on it? What sense does any of that make?
- 6K
