1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
That is the SQ 2.5”?
So all of the stock insulation does fit with stock shield?
Different manufacturer. This one came with its own heat shield and insulation installed on it.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
My research on your profile info, suggest Hurricane Quiet trail muffler ?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
Yes
justinator
- Mar 25, 2007
- Maine
- 2023 Arctic Cat Riot 9000
The top shield bolts to midpipe and turbo and the 2 other bolts arent used. You can pass the bolts in and put nuts on back side to make it look factory even though they arent actually serving a purpose. I havent wrapped the shield around mine yet but I guess guys are just wrapping it around and riveting the 2 halves together and it stays put.My TD SQ 2.5” just arrived today. It arrived with damage so I sent it back but not before getting a peek at it.
I noticed that there are no welded rivet brackets for the wrap around shield, nor does it come with the screw bracket on the top pipe, for the top shield to fasten to.
Did you make your own and weld them on?
Fleecer
- Jun 13, 2014
- 2019 SRX
I put the stock shields on my SQ without insulation. I put the motor side shield first, then the outside shield over it. I used 2 ratchet straps to tighten the shields tight to the muffler and riveted them together with factory big/chrome rivets. I used ratchet straps with no hooks, and put a peice of cardboard under ratchet to prevent denting/marring, making sure ratchet/cardboard on motor side in case it did.
I also riveted the shield to the upper bracket so shields wont ever move up/down or rattle. Been using it like this for 5 seasons, no issues. .
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for that info, I shall pass it on to my buddy. He also received his today and his is AOK!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
I put the stock shields on my SQ without insulation. I put the motor side shield first, then the outside shield over it. I used 2 ratchet straps to tighten the shields tight to the muffler and riveted them there with factory big/chrome rivets. I used ratchet straps with no hooks, and put a peice of cardboard under ratchet to prevent denting/marring, making sure ratchet/cardboard on motor side in case it did.
Thanks for that bit of engineering and shield R&D! Shall pass it on.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Ratchet straps work on quite a few tricks. I use them for, hole line up on rear suspension bolts, compressing the tunnel for ease of snap ring placement, etc..
VX1R
- Sep 19, 2004
- Inver Grove Heights, MN
Current Riders:
2018 SW LTX-LE
2002 SRX Custom
Vintage Riders:
1980 Enticer 300 Twin
1986 Inviter
1998 Phazer Mt. Lite
1996 Phazer Mt. Lite Mod
I like the way your roll Motorhead...
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
That's what I did when I ran it.The top shield bolts to midpipe and turbo and the 2 other bolts arent used. You can pass the bolts in and put nuts on back side to make it look factory even though they arent actually serving a purpose. I havent wrapped the shield around mine yet but I guess guys are just wrapping it around and riveting the 2 halves together and it stays put.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Thanks for all of the replies pertaining to this TD SQ2.5” and it’s shield mounting.
Looks like I have a bit of a wait whereas mine delivered with some damage to the flex joint expandable pipe, and now that I shipped it back, I need to wait until they receive it so I can get refunded and get another.
A good friend and riding/racing buddy also got the same delivered yesterday, and his is AOK, so We talked about welding some mounting brackets on the muffler and top pipe !
So yeah, we have a lot of time before the snow flies, so shall have to look at both stock and SQ and come up with a plan!
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
I would weld some mounting tabs to keep it secure
Fleecer
- Jun 13, 2014
- 2019 SRX
You are not alone my friend. The best ratchet straps for winder repairs imo, are the ones fron Harbor Freight without hooks. T
he hooks just get in the way, or make strap too long!!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
You are not alone my friend. The best ratchet straps for winder repairs imo, are the ones fron Harbor Freight without hooks. TView attachment 161161 he hooks just get in the way, or make strap too long!!
They do have a pretty good selection of tools and other. That’s my main tool spot since our Sears and other tool shops closed years ago. I do have some of those but mine are much shorter and heavy duty for tying my bikes down in trailer when traveling with them. So prior to putting my shield on I shall pay another visit to Harbor Freight, whereas I do want it nice and tight so it stays quiet.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Yes that is our plan.I would weld some mounting tabs to keep it secure
Sure would like to find out what company sources the stock brackets to the muffler manufacturer.
Easy way would be to cut originals off and adapt those. But then ruin stock exhaust.
- 10K
- 16K
