nadekeys
- Oct 20, 2009
- Green Bay, WI
- 2017 Sidewinder LTX LE
2009 Apex LTX GT
2008 Nytro MTX Turbo
I'm not sure this is needed. I just read on the arctic cat site that the low beams already stay on when the high beams are activated. Reads:I was going to put a relay in so the hi beam power activates the low beam circuit on the relay ! Low beam will stay the same. Apparently some doo models have this.
LED W/ ACCENT LIGHT
Features LED headlights for enhanced lighting performance. Want the high beams on? The low beam will also stay on to give you a nice, wide light pattern with excellent distance. Plus, special LED accent lighting comes on when you turn the key.
**sj**
I got her home today..the low stays on with the high already!
**sj**
so I appreciate all the opinions..but with the insert...I have decided to go with the all black...with the all black mohawk skis...and black spoked J&T rear axle wheels...and hopefully a black windshield...
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Black with blue just installed on my ltx le.
Sent from my SM-G928V using Tapatalk
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Make sure you guys get the Hayes brake mounting kit. This pic shows how the left support replaces the stock top piece of the brake clamp and runs over the brake reservoir area.
**sj**
My second choice..love the sled tho lol let's compare notes...what's your thoughts on wiring the leds
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
I'm wiring them direct to a key on power source and not installing the switch. I'm doing that later today so I'll let you know where I end up tapping into.
**sj**
I'm going with the sentinel in blue/black with the fold-in mirrors and the LED kit.
did you install the leds yet and how did it turn out?
I have a complete set of the sentinel handguards and new leds I might sell..
nadekeys
- Oct 20, 2009
- Green Bay, WI
2009 Apex LTX GT
Kind of a long story....I'm trying to get my riser setup installed so I can figure out how I want to mount my GPS, what type of ram mount I want. Once that is done I'm going to wire the AMPS mount and led hand guards. My power Madd riser won't install because of the strange off centered pieces of pipe sticking up off the t-post that the riser mounts to. I'm going to need to trim pieces of the bottom of the riser so it fits. And my dremel burned up, so now I'm waiting for a new one of those also. A lot going on, but yeah I'm working on it!
Mighty
- Apr 17, 2003
- Grand Ledge Michigan USA!
- 22 Mach Z
23 Sidewinder SRX
I installed the switch next to the opposite side of the seat heater switch and connected directly to the battery feed at the fuse box so I can run them trail side at night while my buddy wrenches on his 800 eTec ........I'm wiring them direct to a key on power source and not installing the switch. I'm doing that later today so I'll let you know where I end up tapping into.
yamahaex50
Can we get a pic with the lights and the handgaurds on? I'm waffling on buying them based on how it looks.I installed the switch next to the opposite side of the seat heater switch and connected directly to the battery feed at the fuse box so I can run them trail side at night while my buddy wrenches on his 800 eTec ........
**sj**
So I have the black ones, the mounts...armor and a new set of the led kit...I'm selling..p.m. Me
Mighty
- Apr 17, 2003
- 22 Mach Z
23 Sidewinder SRX
**sj**
Looks great Dan
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
Looks great! Think my viper is getting it
- 49K
- 13K
