1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
What up with the 1049 stub shaft?The exact part number is in the title of the vids I posted on the previous page: KML 6307-2RDQE6. It's mentioned in one of the previous posts, but to emphasize - you need the stub shaft from a 1049cc engine (not the older carbed 973cc). For the price of the seal you might want to replace it at the same time as well.
Look forward to hearing your results.
- Apr 17, 2003
- Menno, SD
- www.ulmerracing.com
- Menno, SD
I just did a brand new 2024 SRX, has 14.7 miles on it, 1.3 hours of run time, all of it on my chassis dyno. Customer supplied the knock out kit with AK's grease. I shoved as much grease in as I could (grease came in a zip lock baggy, not sure how many ounces). It definitely quieted down the rattle even more, ran it up to 190 degrees and can't say I could audibly hear a change as the engine warms up. Will it last forever, likely not, does it help in the present, it appears as though it does.
I am a very tolerant patient person but honestly...I have grown weary of this thread. If you want to ensure a quieter clutch/stub shaft on the Yamaha 998 either buy a different clutch that has been proven to be quieter or buy Hurricane's Clutch Noise Reduction ring...as with most things in life there is no easy button here.
Or the option that I've posted in this thread (and also 2 years ago). 23 pages and counting and I don't see any solution - other than my own - that demonstrably eliminates the issue. Not saying there aren't others out there, but I thinks my videos speak for themselves.I am a very tolerant patient person but honestly...I have grown weary of this thread. If you want to ensure a quieter clutch/stub shaft on the Yamaha 998 either buy a different clutch that has been proven to be quieter or buy Hurricane's Clutch Noise Reduction ring...as with most things in life there is no easy button here.
I wouldn't discount them as an option.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
I tried to explain that to everybody. AK is using Grease that most of us dream of. It's over $100 a tube. Maybe more.I just did a brand new 2024 SRX, has 14.7 miles on it, 1.3 hours of run time, all of it on my chassis dyno. Customer supplied the knock out kit with AK's grease. I shoved as much grease in as I could (grease came in a zip lock baggy, not sure how many ounces). It definitely quieted down the rattle even more, ran it up to 190 degrees and can't say I could audibly hear a change as the engine warms up. Will it last forever, likely not, does it help in the present, it appears as though it does.
I know I've got about 15 minutes worth of ride time on the grease that Tapp supplies.
My best guess is that it has tighter tolerances on the splines. I tried to measure/compare to the Sidewinder stub shaft but it's pretty tough to do with a set of Vernier calipers, which is all I have.What up with the 1049 stub shaft?
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Be nice to see pictures of your knock out ring and what’s left in the stub shaft for grease when u pull it apartI'm going to pull the hub this weekend and repack it with different Grease. And go from there.
That's all I can do.
Doc Harley
- Oct 17, 2016
- Here & there
Yep....I'll get pics on here. I didn't think of that.Be nice to see pictures of your knock out ring and what’s left in the stub shaft for grease when u pull it apart
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
You can throw a load of elephant cum in the damn thing and it’s still a fart in the wind weather it helps or not!
Other than initial idle (for some) this kit is mediocre at best!
iceback
Sorry but common sense will tell you that taking up space in the splines with grease only lasts for a little while , I have both Sidewinder and King Cat one is quite the other ( Sidewinder ) is not , kept both well maintained drive clutches , you do the math , think Hurricane is the only fix .
Doc Harley
- Oct 17, 2016
- Here & there
Well...might be one more situation in regards to the Tapp seal kit. With the lack of instructional guidance, if green loctite was not used, it's very possible the seal & collar could very well stay in place with the shaft, as the hub is removed.
Now I'm not exactly sure if that's ok or not, however I do know guys cannot extract the collar and think it's going to be ok to just put the hub back on.
Motor spinning 9,000rpms. Hmmm
1) is that ok?
2) of not, how to remove?
Your thoughts?
1) is that ok?
Your thoughts?
Where's it going? Do you think it is all going to push past the 0-ring?Sorry but common sense will tell you that taking up space in the splines with grease only lasts for a little while , I have both Sidewinder and King Cat one is quite the other ( Sidewinder ) is not , kept both well maintained drive clutches , you do the math , think Hurricane is the only fix .
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
JT
Why would u not be able to extract the collar ?
Are u saying your collar is no longer on your hub ?
Doc Harley
- Oct 17, 2016
- Here & there
The hub was removed. Collar & seal Separated from the hub and remained on the crankshaft.JT
Wondering if its ok to just reinstall the hub? I think I know the answer.
Note: this is not my sled. Unfortunately, I did not use green on my collar as well. So ill be expecting something to deal with myself.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Not at shop to compare, but is the spline size different on the 973 vs 1049? The 973 did not have gear for crank position sensor but that would not matter on a 998.The exact part number is in the title of the vids I posted on the previous page: KML 6307-2RDQE6. It's mentioned in one of the previous posts, but to emphasize - you need the stub shaft from a 1049cc engine (not the older carbed 973cc). For the price of the seal you might want to replace it at the same time as well.
- 48K
- 54K
