actionjack
- Apr 9, 2005
- Westminster, Maryland
- www.inspectorjack.com
- 2017 SideWinder LTX-LE
Thanks for posting this,The user manuals are located here:
TurboDynamics
http://www.gapinnovation.com/docs/TurboDynamics/
Hurricane/Turbor Performance
http://www.gapinnovation.com/docs/Hurricane/
D and D
http://www.gapinnovation.com/docs/DandD/
The temperature and oil lamps are use for knock warning on the original instrument cluster. Boost and AFR on dash are explained in the latest user manual which I have just put on the server, version 6.0.
Hope this helps, else, please ask.
I had a hard time finding the Flasher Software updater today. It wasn't obvious on the GAP site which auto switches to copi-trail.com. Even if I searched for "flasher" or "updater" or "Turbo Dynamics".
GAP Innovation
TY Advertiser
- Apr 28, 2017
- Repentigny
- ZR 9000 RR, Sidewinder
You're welcome. The new tuner purchasing sites will also house a document and updater section. This will be easier to find...
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
What is the date of the ĺatest update?
Buckeye
- Lakes Region, NH
Build 0521 today.What is the date of the ĺatest update?
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Question for Gap.
Hurricane tune bundle and flasher on board the sled last season and the Spedo would read low vs. GPS by 5 MPH sometimes close to 10 MPH last year. Has this been corrected with latest updates?
GAP Innovation
TY Advertiser
- Apr 28, 2017
- Repentigny
This was actually fixed last season therefore all flashes on our system have the fix. Simply update your GAP Flasher to Build 510 of Program Flash Files Only if already at 510. Then, update the engine ECU...
Hurricane tunes are now adjusted VSS wise pretty close to GPS speed for a standard 2.86 pitch 9 tooth driver versus stock where its a little higher than GPS.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I updated my flasher again today, using updater. New release 0521.Build 0521 today.
Also got time to call Dave finally and he had my flasher all ready to go already.
Then I flashed the latest maps(Jukebox) and then flashed the new Cluster flash.
Its just so simple, and fast....within a minute or two max, all up and running.
Really love this techy stuff, GAP is simply incredible, and I will work with them going forward on any turbo I have. Nice to hear Dave tell me he is well on his way with the 900t from BRP, and will be very soon ready. Being a longtime doo guy and knowing lots of buds will be on these models, I will do my best to get them into the GAP world, that little doo will need a flash to bring it close to our STOCK winders. Will be a nice ride i think.
Dan
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Someone explain the Turbor/Hurricane connection please? Does Turbor do the tuning for Hurricane?
Please? I would like to hear from Dave on this.
DMCTurbo
- Nov 12, 2005
The same goes for TD regarding the Speedo versus gps?This was actually fixed last season therefore all flashes on our system have the fix. Simply update your GAP Flasher to Build 510 of Program Flash Files Only if already at 510. Then, update the engine ECU...
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Just loaded some more info and video to my build thread here:
https://ty4stroke.com/threads/my-rtx-le-50th-build-thread-rockerdan.149801/page-33#post-1448743
Dan
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Question for Gap.
Yeah Mike we talked about this last year...My first test I have a video showed MPH was low as you said(121 speedo and 125 GPS), I saw same thing. Then the next time I tested just a week or two later, it was fixed...and quite accurate too! Really nice to have accurate speedo coming from DOO world where they all think they are going 120mph...lol
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
If you checkout Turbor site, they sell most all same products Dave sells....and I see they are located up in Qc....maybe just a way for Dave to bridge any language barrier to fellow Qc riders? That is my guess.Someone explain the Turbor/Hurricane connection please? Does Turbor do the tuning for Hurricane?
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Yeah GAP stuff like this would be same for both. It was only a short period last season if I recall it was fixed by mid January or so.The same goes for TD regarding the Speedo versus gps?
HURRICANE
- Oct 17, 2007
- Prescott Ont.
- www.hurricaneperformance.ca
Correct dan, dave from turbor and I are good friends. This is a rare friendship that has been built on trust over years. I don’t speak French and dave is fluidly bilingual so it’s a perfect way to take care of our friends in Quebec, not to mention other parts in the world that dave forges a relationshipIf you checkout Turbor site, they sell most all same products Dave sells....and I see they are located up in Qc....maybe just a way for Dave to bridge any language barrier to fellow Qc riders? That is my guess.
Dan
- 9K
