CooperT
- Jan 23, 2015
- Fergus, Ontario
- 2018 LTX DX
2016 RTX SE
I just repacked that bearing, had 8000km on it and it was still nice and smooth, just lacking a bit of grease. No play at all. I have an 18’
2004yamahaviper
- Sep 11, 2010
- Ottawa, Ontario
- Spring order 2021 srx
2012 Apex xtx
2 2021 srx's just rolled 6000km on them haven't looked but no issues yet. End of the season I'll take a look and see if either are spinning on the shaft. If they are spinning yamaha can fix it.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Son in law found some conveyor belt from one of their old balers...lol.Ya,I needed some yamaha limiter straps too, but I just ordered some from one of my suppliers and then cut and drilled as needed.
SumpBuster
- Jul 18, 2003
- Carlisle, NY .
I do mine every year, and prick punch the fit. Seasons gonna be done here next week, so probably do it then and see how it held up this season. 3400 miles (total on sled), so far been ok, and bearing is like new.I just repacked that bearing, had 8000km on it and it was still nice and smooth, just lacking a bit of grease. No play at all. I have an 18’
suburban
my '21 been spinning on the shaft since 200 miles....it can wait till end of season for warranty change
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
Frank’s Yamaha in Essex junction vt has a different fix. It is what I will do next year during my tear downWhat shocks me is the ONLY fix is the BOP wedge? I do not mean in a negative way, as its a great product and works.. Guess its hard to believe another speed shop or someone has not come out with a bearing with a locking collar, etc. Just blows my mind Cat wont come up with a fix!!!! WHY? No way it costs that much to make it right.. Its not money no way! Its as if they want these things to break down and fail? Dealer gets work? Well then at least HAVE SOME fu&*ing parts in stock to fix the #*$&@ you wont with a better design? this includes chaincase
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
What is Frank's elixir?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
Shaft spray welded to a tighter tolerance , pin installed and bearing notched for the pin. Comes as a package. I have installed one on a viper.
ksiesel
- Mar 25, 2016
- Columbus, Indiana
- 2015 Viper RTX-DX with QS3’s, winder jackshaft, RR front arm shaft, 4 wheel kit, and many more upgrades
- Columbus, Indiana
Is this something they are offering for non-local customers? In other words, can we place an order for it and have the parts shipped to us?
Confused
- Oct 12, 2008
- Mound, MN
- '25 Sidewinder SRX #723
'24 MXZ 850 Turbo R Comp
'23 MXZ Blizzard 850 ETEC
'24 MXZ Neo+ 600
'88 SnoScoot
I've used flame spraying on shafts in the past. The surface becomes harder than the original material. Very cool technology.
- Feb 13, 2017
- Amston,CT
- Renegade 900 ACE,XF 9000 Crosstour,2024 Skidoo Renegade XRS 900R
I had Franks repair my shaft with a updated bearing and do all the chain case up dates.piece of mind.You can send your shaft to him and he will recondition it as pictured ,and send you a better bearing than stock with the inner race slotted.phone 802-878-3930 ask for Kamran the Service Advisor,Also pictured is the chain case top gear offered by a vendor on this site,or offered through the B.O.P. SiteFrank’s Yamaha in Essex junction vt has a different fix. It is what I will do next year during my tear down
Updates?I had Franks repair my shaft with a updated bearing and do all the chain case up dates.piece of mind
- Feb 13, 2017
- Amston,CT
Barn of parts sells many of the needed chain case updates,the DMC top gear super bushing (50 % more surface area than stock)and upgraded brass shifting forks,dealer did a tack weld on the chain tentioner screws,replaced the factory RTV seal with Travis’s rubber gasket at the oil tank flange,and just ordered a R.O.V.bypass kit to permanently eliminate the chance of oil tank pressurization due to a frozen valveUpdates?
Ok.Barn of parts sells many of the needed chain case updates,the DMC top gear super bushing (50 % more surface area than stock)and upgraded brass shifting forks,dealer did a tack weld on the chain tentioner screws,replaced the factory RTV seal with Travis’s rubber gasket at the oil tank flange,and just ordered a R.O.V.bypass kit to permanently eliminate the chance of oil tank pressurization due to a frozen valve
I thought u were talking about factory updates....
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Did mine prior to last season.
It was my choice, to have the dealer just give me the parts after he pressed the clogs off and back on the new shaft.
I had heard from someone, that they had done that and even with being particular with both bearing and new shaft, they were still .007 diff between the two.
Mine was a tight fit. Putting it on by hand was not easy, and taking it off after was even worse. But I took my time and wiggled for minutes, and it finally came! Not at all like the video BOP had, showing him slipping the bearing on to a new cog shaft, and simply turning the shaft sideways and watching the bearing simply fall off.
Changed mine out on warranty at 5500 miles, and I had just dimpled the shaft and re-greased the bearing hoping for a couple more seasons, but some on here talked me into just changing it out whereas it was warrantied.
This will be my second season on the new shaft and bearing. Next falls maintenance will tell.
I just used loctite and do have the BOP simple DIY puller template. Have bought many different things thru BOP in the past years. He’s great.
- 14K
