PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
wonder why these triples have such a high initial torque value. the apex's are 85 ft lbs then have the same secondary torque values as ours. wonder why they need to be 23lbs tighter
Lusemeat924
- Jan 1, 2016
- Drumbo, Ontario
- 2018 Yamaha Sidewinder 137 XTX SE
There you go thinking again,,, without the equipment!!
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
you're so gonna get busted on your phone! more corrective action comin your way super chief! lol
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Video is something that should not be looked at for conclusions. I have done this every sled I've ever owned and its near impossible to get the real data on cam(for the viewer). I'm not saying this is a bad thing, after all I have been doing this for yrs when noone else cared.lol
What I mean is....you need to figure this out with your EYES watching, and come to the conclusion first. The video is more or less fluff IMO. Every sled ive run the belt up on stand, has been OFF by eye, some more then others. And I have shimmed them all according to my eye and lowered belt temps. So I believe these type of tests are always helpful.
My videos below(for comparison sake) to yours. Stock mine was set to 62++mm.....and I could detect the slightest dogleg by eye. I eyed it up first tho, then measured...and it concurred with where I felt it needed to go. So I then removed shim, got it closer to 61++mm...and did another eye'd up run, and it looked dead nuts straight bottom to top. Basically could not get it any straighter.
My conclusion was that the 61mm spec is perfect. Anything LESS is bad as the secondary wants to float inward under load. And it will float outward on backshift within the float limits of whichever adjuster you own or till hub hits large stock washer. But I will say the outward movement is rare, and secondary nearly 100% of the time stays inward fully. Only on high speed run up and throttle chop does it try to move outward a tad.
My videos:
62++ mm offset(slight dogleg)
Correct 61++mm offset(perfect) (older video lots of changes since this so some of what im saying back then has changed.lol)
My videos:
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Soupy....
Have you tried to go back to stock just for comparison sake? I have been all over the place testing and its interesting how I am getting back closer to stock all the time.
Just to see how much heat you have with entirely stock setup.
Dan
Dan
Soupy
- Jan 10, 2017
- West Michigan
- 2017 Sidewinder LTX-LE
Thanks for the info Dan. It's much worse by eye, which is why I'm chasing this problem and decided to post. All looks great on the stand, offset is 60.7mm, belt appears straight, but the belt still overheats & blows after 1-200 miles. I was riding pretty slow trails last wknd and got to an opening and blew the belt in 2 seconds.Video is something that should not be looked at for conclusions. I have done this every sled I've ever owned and its near impossible to get the real data on cam(for the viewer). I'm not saying this is a bad thing, after all I have been doing this for yrs when noone else cared.lol
My videos:
Soupy
- Jan 10, 2017
- West Michigan
Yes, long ago. Been blowing belts since new. Reinstalled clutch tuning components because it doesn't seem to matter what I run, still lots of heat.Soupy....
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Do you feel your primary(stub shaft) is moving inward? It sure sounds like this is what you are explaining.
I have often wondered about the stub shaft, and if/how it can move in/out.....also never understood why any clutch bolt would ever have to be torqued down over 85ft lbs...seems nuts. Must be some reason YAM wants this torqued this way.
Im now down 2 belts myself....but both were basically self inflicted I believe. At 270hp and how I beat this thing, i dont blame the belt. I dont have any heat out of ordinary.
If your belts are stripping down, pulling cords ect....that is heat. My 8JP went into tiny pieces, so I think it just gave up due to HP.
Have you tried stock clutching? ALL stock(just add your weights to get rpms where you want) and see how heat is....It does sound like you have other issue but Im seeing cooler temps the closer I get back to stock.
Dan
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
Dan makes a good point. Are the belts snapping in half or blowing to a million pieces?
Soupy
- Jan 10, 2017
- West Michigan
Million pcsDan makes a good point. Are the belts snapping in half or blowing to a million pieces?
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
How are you guys measuring the offset? I am using a tape measure making sure it is level and straight and I get 2-3/8 in which is 60.3 with NO shim behind secondary. I put 550 miles on all stock clutching and offset which was 61.3 and no issue. Changed to my clutching setup in signature wrapped to 3-3 and adjusted the offset to 60.3 by removing shim and across lake at full throttle belt went.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I think there should be a poll.....how many belts blown with STOCK clutching VS how many without stock.
The guys running closer to stock clutching seem to do better....
Im getting closer to stock now, and seeing less and less heat.....
You guys need to remember stock primary spring is a LIGHT finish rate.
But I think SOUPY has something else going on.
rnusr01
- Nov 6, 2016
- CT
- 2021 MXZ-XRS 850
Good idea. I think the reason for the majority of blown belts is heat related first and offset playing a smaller cause.
HMTurbo
- Dec 5, 2017
- Midwest
- 2018 LTX-Le
Million pcs
Under constant power or in and out? Also is the traction consistent or slipping than catching?
My only break (knock on wood) was traction variation from loose to catch on top of a knob. Belt just snapped.
No question with variations in traction we need to use some caution with this much power. All that dynamic load gets chased somewhere. If I were to choose something to fail it would be the belt.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Mine blew when slipping in powder and catching tracks on lake....seems like this is when you need to really be easy on things, I was only going along half throttle and mine went into pieces then.Under constant power or in and out? Also is the traction consistent or slipping than catching?
- 22K
- 215K
