journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Copy/Paste from Hurricane’s FB page just now:
Sidewinder/thundercat belt alignment
as we have heard, some of the sidewinders are good on belts and some aren’t. I thought that I would post what I’m seeing to solve the problem for my clients in the shop.
As an outlaw racer that has had to learn to harness 800hp without breaking belts, I have developed a method of checking clutch alignment at 1-1 clutch shift ratio. This includes a means of measuring the belt to secondary parallel.this is adjusted by changing the secondary clutch offset.
The sidewinder offset is way off on the sleds that are breaking belts. Many times we need to machine the back of the clutch to move it in to achieve the correct offset.the sleds that we have performed this to have not blown belts after
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Soupy maintains the fact that he has checked his alignment settings and they are within specifications. That’s not to say his Center to Center isn’t moving closer together under load. Which would cause his offset to be wrong, or worse yet clutches out of parallel under load.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
johan
- Jan 19, 2015
- sweden
- Sweden
- Viper Xtx mcx 270
On my viper I had to move the engine as my centre to centre was 261mm it's a pain to move it. You need to loosen all engine mounts bolts and you need to pull the engine to the front then retorque the bolts. My ctc are now 264.5mm so it's movable a couple of mm.
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
sj - maybe this is something we all need to start considering. I've seen some pics of people who have added vents, but none are all that good looking. Is there a set you've seen that look like they belong?driving slower doesnt get cooler air in/out in volume or velocity and doesnt turn the belt over as much putting more heat into the belt...
I say as the power goes up....the most important thing to focus on is venting equal amounts of in and out (hvac like) or for off trail a electric fan!
LouTurbo
- Dec 19, 2016
- Vaughan, ON Canada
- 2017 Sidewinder LTX LE, Hurricane Tune on the fly
Pilot Skiis,
- Woodbridge, ON
Has anyone tried the Team setup any compared belt life ?
- Apr 14, 2003
- Hessel, Michigan
And this could be like @johan has mentioned....center to center being off. I was happy to help Johan with his clutching, but all the credit goes to him as he now has his Viper just flying and his clutches are not hot anymore. Yes, I know this is the SW talk, but he's pushing more power than most of us and the center to center is the same.Plus, he was plagued with the same belt issues people are having here.
Out of all the SW's, Vipers and turbo Vipers I have installed clutch kits on and worked on, I have not checked any center to center distances....only offsets which I keep at the top end of the tolerance. I do know how important center to center distance is, but never thought that it could be off more than enough to play havoc on belts from the factory knowing the engines are bolted in one position.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yes all the credit should go to him, your TP setup is horrible.
- Apr 14, 2003
- Hessel, Michigan
That's the center to center....262mm?
journeyman
- Nov 27, 2005
- Prior Lake, Mn.
- 2007 Attak GT
- Prior Lake,MN
Some owners of the TCats on one of the Facebook SW/TCat pages were complaining last week about belt issues too. If some of these machines are dealing with alignment issues I could see it affecting either branded machine.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
He’s also running the 8dn belt which is longer and requires 268.5mm centers, the 8jp is within spec at 262mm. Being off even 10mm won’t kill you as long as you know what to do with your offset to compensate. If you get too long on your Center to Center then there’s the real possibility of bottoming out the belt in the secondary which is never good.
Soupy’s issue appears to be one of maintaining parallel, atleast from the vids.
So 268.5mm CtC is correct for 8DN?
I did not think the engine was movable.
Does anyone know for sure if we can move the engine ahead to achieve 268.5mm CtC?
Why wouldn't YAM just do this from get-go and use 8DN belts then?
Dan
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Dan
268.5mm is the middle spec for 8dn because it’s a longer belt. I believe +/- 2.5mm variation?
262~267mm is the tolerance spec for 8jp. Which puts the middle spec at 264.5mm.
Let’s say your on the low side for the 8jp at 262mm. Be aware that being on the low side of the Center to Center you should compensate your offset to be also on the low side near 58mm.
This will keep the belt straight in the sheaves. Changing your Center to Center or running a different length belt will also change slightly how sled performs/shifts out.
I like to be on the low side of the offset with high horsepower sleds, to much offset is a belt killer causing the secondary to open faster than it should, releasing some belt grip and over shifting.
- Apr 14, 2003
- Hessel, Michigan
I'm going to make a gage
**sj**
- Mar 2, 2004
- southeastern Mich
- 2019 SRX
Dan
I think you are correct Dan I also didnt think the motor was moveable..
- 21K
- 215K
