STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
Try that 35 with your white spring at 0-1.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Wow,than I will have to add weight,to either set of ramps.Try that 35 with your white spring at 0-1.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
yes, but it will really grab that belt.
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Bench grinder,the same way we did it years ago,before ramps were adjustable,i have my ramps set the same on my digital gram scales,all three at 73.3 each,so your next question is how about balance,correct? I removed all mass from bottom of ramps.Beast,
How did you remove 1.6 gram from DTAY-1 if you were running them empty?
What tune and muffler?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Sounds like you have it pretty darn close with the STM’s. You said you have a tungsten in the tip? Heel empty? That’s unusual weight placement.
The dalton’s will push harder down low, they don’t tuck the weight back as much as the STM weights. Generally the STMs have more force up top depending on weight placement.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
They sure do vs my hh's
Beerman
- Nov 22, 2004
- Plymouth, MN
- www.loyalshepherd.com
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
@STAIN what secondary rollers are you using?Mine is Stock muffler, 270 flash, 17 psi of boost.
If he is at 16 psi that 35 may be a better option? Or take a gram or 2 out of the weight.
I really like my secondary wrapped at 0-1 with that Cat green spring at 270hp
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
hows Da trails down in Peru BM?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I THINK I have TP rollers. I added them after the first 200 miles. I am at 3300 miles now. They still are good. checked them 135 miles ago.@STAIN what secondary rollers are you using?
Beerman
- Nov 22, 2004
- Plymouth, MN
- Sidewinder LTX-SE
- YOUTUBE
- arttyszka
My lamas definitely like them. Got another solid 6" of snow today!hows Da trails down in Peru BM?
snowbeast
- E waterboro,maine
- yes
- YOUTUBE
- yes
Hi clutch master,if you are talking about my stm ramps,i have a washer on each side in the heel,mid empty,and tip loaded,one tungsten on left side in tip,and 2 washers on other side in tip,i may add the one washer on right side back to the mix though.Sounds like you have it pretty darn close with the STM’s. You said you have a tungsten in the tip? Heel empty? That’s unusual weight placement.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
I test with gps in 660/1320 and 2000
Crossfire12
- Feb 13, 2017
Same here, I use TD GPS speedometer,great tool you can see the gains.
snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Do you guys mount the TD GPS permanently or take it on and off?Same here, I use TD GPS speedometer,great tool you can see the gains.
- 17K
