You guys get the use of the original YDS tool rather than the Cat made YDST. That's a good thing if based on past. Not sure if in manual but here is Diagnostic Codes from Tech Update Book.
DranttelSS
- Oct 9, 2014
- St. Peter MN
- 2007 Yamaha Attak
There should also be a copy of this with your owners manual!
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
2017 Sidewinder LTX LE
I was really hoping that we would get back the diagnostic mode that the nytros have. That is awesome for trouble shooting electrical issues.
Steve, Can you make sure as they are added to the site we add them to the Sidewinder FAQ for later reference?
Yes I will.Steve, Can you make sure as they are added to the site we add them to the Sidewinder FAQ for later reference?
I will put this in FAQ because many of us don't carry our manual on sled when the code read is needed. All it takes is a phone and Internet this way. Did this exact thing on my SRX over ten years ago. And Phazer 5 years ago. Saved the ride. Feel free to add anything you feel is helpful in this way and I will put it in FAQ.There should also be a copy of this with your owners manual!
This is actually the codes that YDS tool uses is many others also. Look at some of these.
Lean sensor angle. Is there a rollover shutoff? Sure looks like it
What is the radiator fan relay for?
Parking Brake Switch?
Can someone post the normal diagnostic codes from you manual please?
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
WVTurboLTX
- Nov 9, 2014
- 2009 Nytro XTX
It's probably like the nytro. In diag mode you go to fan relay you can hit something and it will turn on the fan so you can check/trouble shoot it.This is actually the codes that YDS tool uses is many others also. Look at some of these.
Perfect. Thank you
Snake
- Mar 3, 2016
- Maine
- 2017 Sidewinder XTX 137 LE
My friend out riding today had a sr26 (?) pop up. Sled wouldn't pull over 80 or 7350RPM.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
Same thing on except sd 26 on my buddy's.My friend out riding today had a sr26 (?) pop up. Sled wouldn't pull over 80 or 7350RPM.
John Ott
- Oct 22, 2016
- Illinois
- 2017 XTXLE Sidewinder
Mine did same last weekend. Dealer called it as "Intake Sensor Code". Reading forums here found others with similar and that intake tubes were loose, so should be easy fix. Another item to watch that I also just learned on another TY forum was that the 2 bolts on the turbo seem to be loosening and must keep an eye on them and possibly need a lockwasher (Nordlock) or some sort of locking technique to rectify.
XIpyretta
- Jan 8, 2008
- Watertown, NY
- 2015 xtx se
Just had my sidewinder out and code SD_42 started flashing, it also said I’m going 261mph ...looking it up it says speed sensor, any idea what’s causing this, just got it back from the dealer doing all the updates and it was running fine.... is this a simple unhook the battery reset fix or worse?
- 56K
- 11K
