Grasping at straw here. Has anyone checked to see if speedo is accurate when read in Kilometers vs MPH?
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
- 2014 SR Viper LTX SE
2014 SR Viper LTX DX
2001 Venture 600
Given to a friend - 1998 SRX 700s
Thanks Testmaster. It really does not make sense that all models are affected the same. Should be impossible. Doesn't matter. If not capable of getting that right in any one model it makes whole flash suspect with good reason. This is the third attempt. Looks like there will be a fourth. Maybe they will do it right and send it by mail for Christmas ecu and harness. Otherwise it's probably going to be a Evo flash for me and very good possibility that I will never buy a Yamaha again.
Actually when you break it down to lines of code and someone puts a correction factor on one line that inadvertently gets buried into a software segment that is copied into all of the different software products it is very possible and easier to do, and miss, during inspection and testing than any other method that has been discussed. Because if you miss it once you will most likely miss it every time because it's the same people and process.
upei93
- Apr 27, 2008
- Dalhousie, NB
- 2015 Viper X-TX LE MPI turbo
2009 Nytro XTX
This might explain why my XTX LE was doing 105 mph (speedo) with throttle left on my ride after the flash...the LE has 7 tooth drivers and shouldn't be able to see those speeds. I'll have to dig out the GPS.
Pat Cat
- Nov 27, 2016
- Granby, QC Canada
- 2016 Arctic Cat ZR7000 LXR 137
2011 Arctic Cat Z1 1100 N/A
Previous:
2014 Arctic Cat ZR7000 Sno Pro 129
2013 Arctic Cat XF1100 N/A LXR 141
2009 Arctic Cat TZ1 LXR
2009 Arctic Cat T570
- Granby, QC Canada
kilometer for meGrasping at straw here. Has anyone checked to see if speedo is accurate when read in Kilometers vs MPH?
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
The lead tech's brother has a 2016 XTX and I believe it's a LE and his sled is reading 25% slower than before the flash not faster. Check to make sure someone did not change your speedo to Kilometers per hour after they did the flash. I can't see any other way you could be seeing a 107 on your speedometer.
ccmviper
- Sep 11, 2016
- Newfoundland
- 2010 Nytro xtx
2016 Viper MTX 141
2018 M8000
Ive been riding mine in km's and nothing seemed off to me, not really obvious anyways.But maybe it is.I'll check on my next ride.Do the 17's have this flash?
Dinner
My STX DX doesn't seem off either, however I will check tomorrow via GPS when I go out for a ride.
And to "Allen", my 2015, 141 STX DX has 7 tooth drivers, 21/41 gearing.
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Don't worry I was so suprised I checked twice...saw 104 and 105 on 2 different stretches...my boost guage was also reading a bit hi from what I could see. I bought this sled used so I'm not sure what had been done to it before me...besides a G Force clutch kit and a 1.75 track. I put an Ulmer kit in an 8 dn belt and a osp adjuster and boost and AFR gauges. I just dug my GPS out so I'll compare when I get a chance.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
It could have been geared differently by the previous owner but that would indicate you are running 130+ MPH!!!!!
upei93
- Apr 27, 2008
- Dalhousie, NB
2009 Nytro XTX
Ulmer's the man!!!! Lol
Quipper16
- Feb 2, 2014
- Sudbury ON
- 2016 Viper xtx
Last 2 days when i cold started my sled I held the key a little longer after it fired and it stayed running. hopefully this works out. these 2 days is wasn't as cold as last week though.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
If not anything else this flash will keep the mileage down on the odometer for resale! 25% down.
TestMaster
- Sep 28, 2013
- Alba, Michigan
- www.gdls.com
2001 Venture 600
A silver lining to every cloud!
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
I have not done the flash as of yet and don't think I'm going to as I have no problems. I also have a 9 tooth driver with a 2.86" pitch track .Allan I know nothing involving Yamaha for sure anymore. Would be best to just look and then test with GPS or known good speedo sled or car for that matter.
Allan
- Oct 19, 2014
- Newfoundland
- 2016 Sr Viper XTX
your stx dx is total different sled than mine I have a 146 " track. mine has 9 tooth driver and 24/50 gears .My STX DX doesn't seem off either, however I will check tomorrow via GPS when I go out for a ride.
- 11K
