08nytro
- Apr 7, 2007
- wisconsin
- 2012 nytroxtx 2010 vecter ltx
how do i get your steering post kit
iuote="UP bushman"]I will be out of town until Sunday, PM me if you want to purchase Bushing Kit.[/quote]
porkchop
- Aug 19, 2010
- Central NY
- Nytro Nation
Rob,
You've got Paypal
$$ sent today for a steering kit.
Thanks, Greg D.
You've got Paypal
Thanks, Greg D.
08nytro
- Apr 7, 2007
- wisconsin
to tight
hi started installing your steering kit, when I tighten bolt to 27ft lbs I cant move the pivots, seems like the brass bushing should have been a little longer?
Psycho Dave
- Jan 8, 2013
- Norderåsen
- Sweden
- 2021 Arctic Cat Riot X
1986 Aktiv Karibo
I had de same problem, I sanded down the plastic washers just a little bit.
canoehead
- Jan 14, 2011
- NE, Alberta
- 2014 XF9000, 2016 Viper XTX
Back down on the torque value just slightly to avoid premature wear. I installed this kit 2 seasons ago. Every sled wears slightly differently. I'm not speaking/representing the manufacturer, just my own personal experience.
I'm also very happy with the product overall.
Re: to tight
08 what year is your Phazer? I am very surprised by this. It could be the kit was designed to take up play in a well worn sled like mine is. Not sure but as a former Machinist I do know that UP Bushman hits the numbers right on. Very accurate machining. The torque should not matter and it is important safety wise to torque it correctly so if a few rubs on a piece of sandpaper are needed to make a bit of clearance please do it. Do not loosen the bolts to get it free. Everyone makes a mistake once in awhile he may have in this case. Are you sure you didnt just use to thick of a shim provided in the kit?
08nytro said:hi started installing your steering kit, when I tighten bolt to 27ft lbs I cant move the pivots, seems like the brass bushing should have been a little longer?
- Nov 1, 2009
- Winnipeg, Manitoba
- 2009 Phazer RTX
Re: to tight
X2!
cannondale27 said:08nytro said:hi started installing your steering kit, when I tighten bolt to 27ft lbs I cant move the pivots, seems like the brass bushing should have been a little longer?
X2!
canoehead
- Jan 14, 2011
- NE, Alberta
Like I said I backed mine off slightlyUP bushman said:Hey phazerdrew I backed mine off a touch and there were good a little snug. The Collar on the stock Bushings are a bit longer so when torqued tight they still moved quite freely. Any slop that is left in the Steering System is in the ball joints thanks again.
Mountaintech
I highly recommend this product! Thanks again UP bushman.
herff
Rob,
You've got Paypal.
$$ sent today for a steering bushing kit.
Thanks, Steve.
You've got Paypal.
Thanks, Steve.
Jehr
- Jan 19, 2014
- Ottawa, Ont
- 2007 Phazer MTX
2018 Sidewinder STX-DX 137
Hi, I just picked up a 2007 Phazer MTX, so I am new to this forum. The steering needs some work so I would like to get an UP Bushman kit. I PMed UP Bushman early last week, is he still making these available?
Thank you.
Thank you.
UNSC_WARRIOR
Same here. PMed UPBushman last week but haven't received any reply yet... Are the kits still available?
biffdotorg
- Dec 2, 2008
- Pelican Rapids, MN
- www.biff.org
- Apex XTX and Viper LTX SE
- www.biff.org
I'm pretty sure I will be doing this kit as well in the off season. I will wait to hear back on this thread too.
TY!
TY!
iwant1
I NEED one of these kits, actually both of them. I bet there is 2' of bar play in mine
UNSC_WARRIOR
Has anyone heard from UP bushman lately? I tried emailing him but I keep receiving delivery failure notifications saying that the account doesn't exist.
