woodzynh
- Sep 11, 2012
- Nashua, NH
- 2015 Yamaha Viper XTX LE
Just sent this to my dealer as they are not aware of this situation.
Same here, nothing for Yamaha yet
- Apr 14, 2003
- Hessel, Michigan
You won't see anything from Yamaha for another few days.
Mine is xtx Se (But they were still holding.....not by much)
Nordlocks buddy. Do it right and move on. Will bring some over.You won't see anything from Yamaha for another few days.
- Apr 14, 2003
- Hessel, Michigan
Cool
Shagnos
- Jan 23, 2007
- Slowville mi
- Sidewinder
I use heat to remove that gasket maker....Yamaha will come out with it and I am guessing this will happen next week.
Problem is...these guys are riding now so a temp fix with High Temp gasket maker on the threads works just fine.
yamaha06
What size nordlocks do we need? Haven't even checked my turbo bolts but would be interested in installing these since it seems like it should solve the issue.
I wanted NosPro to try them to be sure but this is a Arctic Cat Flange bolt with 13mm head. Want Nordlock to have full coverage and these do. Got these at McMaster Carr years ago so no part#What size nordlocks do we need? Haven't even checked my turbo bolts but would be interested in installing these since it seems like it should solve the issue.
21mm/.825in OD
10mm/.405in ID
Here you go. These should work http://www.mcmaster.com/#91812A431
Or if you just want steel get
3/8" 0.410" 0.830" 0.090"-0.110" Rockwell C46 10 91074A331 10.06
Product Detail
Zinc-Flake-Coated Steel Wedge Lock Washer for 3/8" Screw Size, 0.41" ID, 0.83" OD
Please complete the specification for this item.
Packs of 10
Product Detail
Packs of 10
silverram323
- Mar 24, 2013
- Jodrell St, Cambridge, mn 55008
- beyondsynthetics.net
- 2017 Sidewinder XT-X 141
Two out my three were finger loose. 72 miles on the sled.
The inner bolt is a bitch, but after trial and error I figured out a way.
I found a short and shallow 13m, put the adapter on it, then slid the 1/4" wrench on it. Worked well, it was tight. I also made a spring tool, I normally use a vise grips, but no room in this monster.
I didn't have a T50 ball end socket so i made my own.
Sent from my iPhone using Tapatalk Pro
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Very creative!
Silkysmooth3popper
- Mar 19, 2013
Thanks for the pics. I gave up on the rear bolt... Just couldn't get on it good enough. I have read somewhere that a u-joint and socket worked, but I say bullshit because I tried. Will try again with your method!
done dooin'_winder up
- Dec 6, 2016
- saegertown pa
- 2017 sidewinder stx 137 dx
i gave up on rear for now, nordlocks on front 2. will keep an eye with mirror and finish when i do a can and tune.
Doc Harley
- Oct 17, 2016
- Here & there
- '17 Sidewinder LTX SE
Thanks for sharing....... Joe
Q. Arrius
- Feb 6, 2015
- Indiana, (central)
- '17 Sidewinder LTX LE (red)
'12 Apex SE (black)
'12 Arctic Cat F800 snopro (129, orange)
'15 SRX 120 (blue)
''15 S.Doo Renegade XRS (Ronald McDonald colors)
Thank you for sharing your great ideas on getting it done! Much appreciated!
Q. Arrius
Q. Arrius
Doc Harley
- Oct 17, 2016
- Here & there
I'm not very creative. Had some returns to do.....
