Blue shadow
How long have you been doing this ?Any trouble in keeping it alive ?thanks
WesG
20-22 psi
Ran 20 for one ride LOL Destroyed my 2ndary clutch. Runs awesome there though. I will be back at 20 when I get a replacement clutch Motor seems fine, no coolant loss or anything odd. Head shim w/cam timing done to PL specs.
Wes
Wes
Ted Jannetty
I am running 22-23 psi depending on the weather.
Original Stock 03 RX1 Never Opened other than Head Stud Retorque when I installed the turbo.
Ted.
Ted.
millstreet
- Dec 6, 2005
- doylestown, pa and old forge, ny
- current - 2018 Sidewinder ltx-le 50th
No compression reduction on the Ted sled?
Climbmax
26 on a stock motor with only a shim and head studs.
lakercr
Tech Advisor
Over 20lbs here with 10:1, Carillo rods, cam timing, HD studs. Motor is still strong after a season of abuse, but it is coming apart anyway for one of Dave's blocks.
lakercr
Tech Advisor
Climbmax said:26 on a stock motor with only a shim and head studs.
What altitude Randy?
Blue shadow
most are having good luck with the stock rods,I see .When doing 660 ft runs how long do you let it cool down before making another pass?thanks
when you are running over 20psi, what fuel do you running on??
And what compression do you get whit low comp pistons?
Blue shadow
165 psi with c12 race fuel and meth
Climbmax
Cilius66 said:when you are running over 20psi, what fuel do you running on??
100% propane...it has been tested to 30lbs of boost
Climbmax
lakercr said:Climbmax said:26 on a stock motor with only a shim and head studs.
2,000 meters
fullthrottle800
Basically I wouldnt say no if Randy wanted to give me that sled.Its awsome.Mabye by the time BIS comes around he will be tired of it and hand over the keys.
Otis RX
The thing is an animal at 20#.
Ted Jannetty
millstreet said:No compression reduction on the Ted sled?
No, Engine has Never Been Opened.
