- Apr 14, 2003
- Hessel, Michigan
Are you running a header Terry?
I have the header as Dave @HURRICANE modified it to the 2nd gen header and will be installing it with the header tunes.
Turboflash
- Mar 18, 2019
- Southern MN
VERY NICE!Thanks to @HURRICANE this sled is a monster!
It's datalogging from Hurricane to an I-pad that I am still learning how to operate. But, it is my dash now and shows the engine functions. But the datalogging is priceless for tuning and recording runs. I just bought all of this recently and hooked it up 2-3 weeks ago.
My son taught me how to do a screen shot last night....LOL. Now I see a camera on the side where I could take a pic...LMAO!
This shows the max mph and trying to get the screen to stop on the exact point is hard. I was already off the throttle at this point. But shows the tune I was running also. If there was a knock, it kicks it down to the next tune which would be 270SS.
But I love this technology to record everything. The pic at the bottom is one I found on the internet showing how it is mounted.
- Apr 14, 2003
- Hessel, Michigan
MPH says 132?
The MPH reads that 132 cause I was already off of the throttle (notice the throttle position is not 100%). The 132MPH is in real time as the 142MPH was max.
Going through the file again, the speed and MAX track speed were the same at 142MPH, I just needed to "stretch" out the data lines further which makes it easier to read and pinpoint on.
@0degC If I put in a SIM card, would the I-Pad have an app to have GPS so I can get rid of my other GPS?
- Apr 14, 2003
- Hessel, Michigan
Are u sure these speeds are correct.
Seems fast for the power level.
I know my 18 with the 141 read much higher than actual due to the different drivers with 3 inch pitch.
Try a Dragy out, or use the speedometer69 app.
I think you will find that your mph is off by over 10 mph at least
Yes, the speeds are within 2mph of my Garmin gps
I need to get our TD gauge hooked up so I can have 60ft, and the other measurement data.
- Apr 14, 2003
- Hessel, Michigan
@Crossfire12 Might have to pick your brain on the TD gauge....
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
A Dragy works well as you have all the data on your phone.Yes, the speeds are within 2mph of my Garmin gps
- Apr 14, 2003
- Hessel, Michigan
What if cell phone reception is bad? Still works?
Dragy GPS performance app?
DMCTurbo
- Nov 12, 2005
Yes it Bluetooths to your phone. Great tool to have. I had the TD GPS, dragy is better in my opinion.What if cell phone reception is bad? Still works?
- Apr 14, 2003
- Hessel, Michigan
Just downloaded it to my phone
DMCTurbo
- Nov 12, 2005
You have to purchase the Dragy. Best place is Amazon up here North of the border.
DMCTurbo
- Nov 12, 2005
You can set custom distances, 0-140 mph as an example and it will tell you the distance it took you to hit that mph. Very cool.
THEPASMAN
- Mar 25, 2019
- The Pas Manitoba
- 2017 Sidewinder LTX LE
Just quick question about the Dragy how does it work
does it connect to the sled via wire or is it a little GPS unit all it’s own
do you have to push a button before a run
Quite interesting
Quite interesting
Works the nuts installed here Terry
DMCTurbo
- Nov 12, 2005
Small device that magnetically mounts to your sled. It connects to 2 satellites. It's wireless. Charges with a USB. It doesn't lie and you can't cheat.Just quick question about the Dragy how does it work
Quite interesting
- 35K
- 104K
