the gt 20 is to small on the turbine side, it has way too much backpressure and will cause higher egts and less hp, you will wreck the engine with continued use. the gt25 is a much better choice. it is our base turbo and works great for all applications, if you want alittle more hp, and are willing to give up alittle low end response, then the gt28 is for you. i can set you up with either turbo that will be a direct bolt on to your kit. as for turbo sizing. you have to look at the maps to see where you are, and where you want to be, there is alot that goes into sizing a turbo. jeff
- Mar 1, 2004
monker
Finally some nice weather on a Sunday. Running at ESTA temps were in the mid 80's with low humidity. I left the time slips in the trailer, so going from memory here's the times from my 5 runs...
60' -- 1.48 to 1.51
1/4 -- 11.14 to 11.21
mph -- 111 to 113
Lost in the quarter finals running 11.14 on 11.16 dial.
This was with rpms at 9800 climbing to 10000. Not where it should be, but didn't want to change anything during eliminations with only 2 trial runs. Very close to my top time, so this is good sign for once I get the weights figured out for the new helix.
60' -- 1.48 to 1.51
mph -- 111 to 113
SOFA-KING-FAST
Nice job Corey,did you have to make many changes when you went from a 15 to 10.5 track?and were 60ft close to the same?
monker
I never ran a 15" track. I've got the 136" rear suspension so only the 10.5 is available. I think Terry has run both.
- Apr 14, 2003
- Hessel, Michigan
Corey - I see that clutching info is helping. That is what I ran all last year.
Will send the Chok today.
Allen, got clutch parts on Saturday.
Tyler, suspension/track is in, cylinders are back on, and chain case is all new. it fired right up, and just a few more items to take care of, and it will be ready for her maiden voyage with the new owner. ($%^&, are my fingers and back sore!)
SOFA-KING-FAST
Terry keep us posted!!
Terry do you need help setting the powervalves?Are you going this friday?I'm letting my buddy run my sled he has ran grass for years at nsra but got out of racing this year because of family issues of never being around.
- Apr 14, 2003
- Hessel, Michigan
I am planning on it, but don't know for sure. Tyler told me to power up the powervalves, and check them at full by the exhaust port. I have them matched pretty well.
I am going if some personal things don't go right. Went to the doctor yesterday, and didn't hear the best of news. The possibility of having a tumor on my 8th Accustic nerve in my right ear. But need to wait it out a week. Not letting it get to me tho.
Just got back from the track with the vector.I tried a softer compound beldt which it was way to tight and spun the track.I brought the engagment up 600rpm's higher and my 60ft's picked up.
1st run
60ft:1.64
1/8:7.13
mph:94.39
1/4:11.43
mph:110.01
2nd run loosen the beldt but way too loose I didn't have the right size washers along
60ft:1.44
1/8:6.87
mph:94.30
1/4:11.23
mph:108.25
3rd run went back to the stock beldt
60ft:1.43
1/8:6.84
mph:94.44
1/4:11.20
mph:108.19
4th run spun the track slightly off the line
60ft:1.49
1/8:6.89
mph:94.96
1/4:11.23
mph:108.66
We also got my buddies 2001 srx out with the stock skid modified to fit a 10 5/8 track.The clutching and everything is stock except we took the air box off and left the stock jetting in with 87 octane.
60ft:1.58
1/8:6.83
mph:101.58
1/4:10.91
mph:116.01
1st run
60ft:1.64
1/8:7.13
mph:94.39
1/4:11.43
mph:110.01
60ft:1.44
1/8:6.87
mph:94.30
1/4:11.23
mph:108.25
60ft:1.43
1/8:6.84
mph:94.44
1/4:11.20
mph:108.19
60ft:1.49
1/8:6.89
mph:94.96
1/4:11.23
mph:108.66
60ft:1.58
1/8:6.83
mph:101.58
1/4:10.91
mph:116.01
SOFA-KING-FAST
How consistent is your friends stock skid?Is that a new track or was it broken in prior to his sled?Nice
#S if thats his 1st time out.
It ran just about identical et's all 3 times.Yes the track is brand new not even broken in.The thing is hooking up but probaly carrying the the ski's about 16" all the way to the 60ft mark.Next week I'm going to throw some of my clutch parts in it and he's going to tighten the rear spring.I put a solid adj. strut in place of the center shock and took off the transfer rods.
SOFA-KING-FAST
PRO116 keep rocking nothing nicer than a stout SRX
- Apr 14, 2003
- Hessel, Michigan
Saturday 7/30/05
Temp 89° with 50% humidity, and a headwind of 27+
Took Tyler's SRX down the track for her 1st runs.
1st run - Spun so bad, I backed off a couple times. (Reaction time .052)
1.566 60ft - 6.409 1/8mile @ 108.537mph - 10.151 1/4mile @ 126.892mph
2nd run - spun again, and backed off. Carb top cap came off at the end of the run also. (Reaction time .003)
1.558 60ft - 6.565 1/8mile @ 106.060mph - 10.411 1/4mile @ 123.108mph
3rd run - spun again, but held on to it. (Reaction time .000)
1.492 60ft - 6.477 1/8mile @ 105.411mph - 10.344 1/4mile @ 122.855mph
1st RX1 time run (Reaction time .075)
1.471 60ft - 6.866 1/8mile @ 95.856mph - 11.166 1/4mile @ 110.213mph
2nd RX1 time run (Reaction time .038)
1.475 60ft - 6.889 1/8mile @ 95.934mph - 11.202 1/4mile @ 110.046mph
1st round eliminations (Reaction time .087, Dial-in was 11.14)
1.467 60ft - 6.818 1/8mile @ 97.054mph - 11.043 1/4mile @ 113.144mph
(Wind died down to 3mph, and had to run my best buddy Ken Ziats, who redlighted by a very small amount. A lot of people breaking out that round.)
2nd round eliminations (Reaction time .158, Dial-in was 11.03)
1.472 60ft - 6.799 1/8mile @ 97.893mph - 11.019 1/4mile @ 111.207mph
(Lifted right at the line, and broke out by .011)
Oh well, my first perfect .000 light on the SRX from Tyler, so the girl is showing her potential.
SOFA-KING-FAST
Yep
