jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Pulled my 2017 apart. I had a new shaft/bearing/ BOP wedge BEFORE last years riding. Torqued @45 pounds. I installed the wedge so the washer was approximately 1/8 from flush. So not as far in as some have been going. Not saying the way I installed is better, just giving details. I did not use any bearing lock. Approximately 2000 + miles on this shaft(last years riding)
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
This is Good news. Looks like we're good to go. Looks like you peened it for good measure.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yea I put a few hits on it.. But very happy with what I saw for results on the BOP wedge..
Wonder what a few deeper dimples would do with bearing lock in the peen holes? My concern would be removing the bearing for service every year.
FrozenTows4
- Nov 6, 2014
- 2014 XF7000 Sold
2017 ZR6000RS
- YOUTUBE
- FrozenTows1
Don't mess with success. Bearing is locked and easy to service. I think we've found the sweet spot.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
The issues concerning a wedge that does not fit some 2020 shafts is the same issue that requires the wedge in the first place....tolerance fluctuation!
Earlier runs of these that were shipped out had thinner washers and shorter bolts. I switched to thicker washers, but had large stock on the shorter bolts. Once the shorter bolts were depleted I did upgrade to longer bolt. Last 200 or so that shipped out have longer bolts.
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Was at a Cat dealer a year ago and the mechanic confessed he'd seen lots of shaft problems - 9000's, 8000's. Its a terrible design. Between lots of hp on the shaft, a flimsy tunnel allowing tons of flex and likely that brake puts tons of strain on the shaft breaking it loose from the bearing - its no wonder it cant hold.
MS
MS
theCATman
It's a completely garbage design. This just goes to show how Yamaha doesn't give two flying phuks about us lowly peons buying their rebranded Cat chit. If they(Yamaha) did, they would have corrected this BS years ago before the Viper was ever introduced.
Just keep buying their junk, they'll keep making it the same way.
scooterwj
I put in a new driveshaft this year. I didn't hone the ID of the shaft, I instead made the wedgie a little smaller with emory cloth. Mine snugged up at about 12 ft lbs but final torque to 30
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
You better go back to the Vector no problems with them, better rideIt's a completely garbage design. This just goes to show how Yamaha doesn't give two flying phuks about us lowly peons buying their rebranded Cat chit. If they(Yamaha) did, they would have corrected this BS years ago before the Viper was ever introduced.
Turboflash
- Mar 18, 2019
- Southern MN
Just did annual maintenance on two 2017 TCats both with about 5000 miles. Both had installed BOP shaft saver last year after both had to replace track shaft due to shaft spinning in bearing. Both installs last year were with new shaft and new bearing and BOP shaft saver. In addition, both stalls were done with green sleeve retainer loctite. Both shaft savers were torqued to 45 ft.lbs. Result: both shafts looked great, no evidence of spinning, bearings and shafts like new. Re-greased bearings and re-installed same as before - green loctite and 45 ft.lbs torque.
Conclusion: this method seems to work to prevent spinning.
PowderFalcon
Pinnin' it!
I would torque it double that amount
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Any issues removing with the green lock? I’m assuming you had to put some heat to the inner shaft? I’m leaning towards some bearing lock but don’t want to fight with it when it comes time to service. thanks.Just did annual maintenance on two 2017 TCats both with about 5000 miles. Both had installed BOP shaft saver last year after both had to replace track shaft due to shaft spinning in bearing. Both installs last year were with new shaft and new bearing and BOP shaft saver. In addition, both stalls were done with green sleeve retainer loctite. Both shaft savers were torqued to 45 ft.lbs. Result: both shafts looked great, no evidence of spinning, bearings and shafts like new. Re-greased bearings and re-installed same as before - green loctite and 45 ft.lbs torque.
Turboflash
- Mar 18, 2019
- Southern MN
No problem removing bearing housing using the puller Travis at BOP drew up. I made mine with 3/8" thick steel plate. Uses the 3 tapped holes in the caliper housing and pushes on end of track shaft. Works great!Any issues removing with the green lock? I’m assuming you had to put some heat to the inner shaft? I’m leaning towards some bearing lock but don’t want to fight with it when it comes time to service. thanks.
- 6K
- 58K
