stgdz
- Mar 27, 2021
- Buffalo MN
Loved finding this one after pulling it out of storage. For some reason the rear bolt backed out and slightly egged out. I check this thing religiously because I've always had a problem with egged holes.
So what do I do? Some people say fill and drill but my welder says that always weakens the aluminum. I wish it was steel like my kids RR so I could just mig it. I do have the Lenoco steel bushing inserts that I put on the kids RR rail but I'm not sure if I have enough material to use it.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
I make a repair kit plate for the 137 drop brackets.
stgdz
- Mar 27, 2021
- Buffalo MN
Do they come in black?
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
Travis has a repair plate. And I bought the piece under running board, drilled out the crazy rivets and put new plate in. Was a pain in #*$&@ an only fixed half the thickness of hole. I’ve heard some people tacking in a washer on backside also
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Yamamark made his own brackets for this.
It is post on here somewhere.
I think he put a bushing in there also.
Richard Hodgins
- Mar 5, 2019
- Ottawa ontario
- Yamaha powered CAT
Buy a skid rail insert and drill out your hole slightly larger. Arctic cat part 3604-266 which is $3.25. This insert is where the front suspension arm mounts to the rail so it's good quality bushing that I have yet to see wear out.
It's basically a bushing with a large shoulder on one side. No need to weld a washer on if you use this. Press this in from the inside and you're good to go. Part #2 in diagram.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
That’s what I did for my cross shaft for center shock tooBuy a skid rail insert and drill out your hole slightly larger. Arctic cat part 3604-266 which is $3.25. This insert is where the front suspension arm mounts to the rail so it's good quality bushing that I have yet to see wear out.
It's basically a bushing with a large shoulder on one side. No need to weld a washer on if you use this. Press this in from the inside and you're good to go. Part #2 in diagram. View attachment 169057
I wish those inserts were stock in every hole! I am pretty religious about cleaning,Loctite,Torque and even paint marking but still have been bit by a loose bolt on occasion. Part of the problem is the Powdercoating on rails/brackets behind bolts. It deteriorates and then you have a loose bolt. I noticed on Polaris skids they dont Powdercoat behind the bolts.That’s what I did for my cross shaft for center shock too
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
I ageee. It’s in the front arm why not every pivot point? It’s a minor thing but that an top gear are 2 biggest imoI wish those inserts were stock in every hole! I am pretty religious about cleaning,Loctite,Torque and even paint marking but still have been bit by a loose bolt on occasion. Part of the problem is the Powdercoating on rails/brackets behind bolts. It deteriorates and then you have a loose bolt. I noticed on Polaris skids they dont Powdercoat behind the bolts.
stgdz
- Mar 27, 2021
- Buffalo MN
Because of cost.
Also the RR has steel as the drop link.
fxnytrortxkid
- Apr 19, 2007
- Rensselaer, ny
- 09 nytro rtx
They are $3 a pair I remember. And 4 places to put them, 1 already has them.Because of cost.
I never saw a RR with a steel drop link. Mine didnt have them.Because of cost.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
My rear skid mount repair!!
get her a bagger or tow behind lawn broom and you only have to rake near objects. easyest way to rake the lawn i know about without paying some one to do it.
ty4stroke.com
stgdz
- Mar 27, 2021
- Buffalo MN
Juniors 4000 has a steel sectionI never saw a RR with a steel drop link. Mine didnt have them.
stgdz
- Mar 27, 2021
- Buffalo MN
- 8K
- 12K
