Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
yes ,
i am sarcastic a little Over this hose...![]()
I’m all over it. It will be found or we will blow it up lol
McKabe
- Dec 13, 2020
- Marenisco, MI
- 2018 Sidewinder ltx dx
Had this same issue with mine. Juat spent about 6 hours pressure testing, tightening hose clamps and doing a leak down. Finally got it to hold pressure and thing I have it figured out. Main clamps that were loose were; front heat exchanger, coolant bleeder block, and bottom of t-stat housing. Got the whole damn sled apart for it so I tightened every clamp in sight. Finally held the 16psi for a few hours.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Oh NO, not the RedNeck tune up AGAIN.I’m all over it. It will be found or we will blow it up lol
might be for the best..LOL
- Sauk Prairie, WI
- www.ty4stroke.com
Mine will lose a bit of coolant from time to time, but it’s only when it’s really cold like it was 2 weeks ago. It might lose an ounce or so, and drips out right below the overflow. Fast forward to last weekend, I rode about 250 miles in 3 days and hasn’t leaked a bit.
I have seen this on a few of mine also. I think we have found the problem. I will know in a few days if we can get some riding in.
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
what do you think it is?
When I pressure tested it, it was leaking up around the cap and thermostat. But until we get the sled out, we wont be sure. No other leaks showed up.
She finally let go.. it was the head gasket seeping.. pile of #*$&@!!
STAIN
- Feb 29, 2004
- Vermont
- Vermont
PEFI tune? Is this coincidence or trend?
I wondered if it was over-boosting.. he did see 18 psi on the Stage 3 and 16 -17 on stage 2, and I thought that was odd.. but his exhaust is almost a straight thru design. I am going to check with Thunder and maybe see if there is an update on that tune package.
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I dont want to be "Jonny Skeptical" BUT......I wondered if it was over-boosting
It seems when there are burn down/gasket problems on tunes, this tune comes up often.
My guess is the tune for sure caused the failure but there are a lot of factors that can go along with that failure.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
<runs PEFI tune...on motor #3>
- Status
- 11K
