Mototown
- Sep 11, 2018
- Apex 40 th
Was the reverse gear fully engaged into the top gear ( to the left ) before the servo motor was put in.
That first video with it pulling away slow sounds like chain case noises
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
I am 100% sure its comming from the left drivers! Lube it whit anything you want,( just the left one)the soud will almost disappear
Extrovert is 5/8. Window is 1" not a lot of room for error.. left drivers need to move for perfection!!!! As @ClutchMaster said RIDE IT. Nothing will break
You listen to the first video?I am 100% sure its comming from the left drivers! Lube it whit anything you want,( just the left one)the soud will almost disappear
Extrovert is 5/8. Window is 1" not a lot of room for error.. left drivers need to move for perfection!!!! As clutch master said RIDE IT. Nothing will break
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yea now that I actually see how slow he is going with so many pops and hardly even moving I agree it’s a chain case deal probably.You listen to the first video?
Mototown
- Sep 11, 2018
- Apex 40 th
Or bottom gear is in backwards or not lined up .
Sounds like the chain is trying to derail off gear , then popping back on to gear , making that click sound . Track isn't moving fast enough in first video to be drivers , for how loud it is .
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yep what he saidOr bottom gear is in backwards or not lined up .
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
PF you put something together wrong in the chain case
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Yes. There is 2 type of clip on these track! Thats were the sound come from. Drivers/clipYou listen to the first video?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yea but there’s too many pops for only moving 5 inchesYes. There is 2 type of clip on these track! Thats were the sound come from.
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
Listen carefully this video! Rubber sound,,,,rubber sound,,,,,clip,,,,,, Again an again! The "tick or click" sound we hear is the 1 on 3 clip that goes against the extrovert
I do hear the squeak of the rubber but in the first video when he is actually riding it its crazy loud and at a point track is moving only slightly before each ratchet sound. Never have I heard anything this loud in a sled that was in proper form.Listen carefully this video! Rubber sound,,,,rubber sound,,,,,clip,,,,,, Again an again! The "tick or click" sound we hear is the 1 on 3 clip that goes against the extrovert
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
I say something in the chaincase ain't right... If it was the drivers they would have worn themselves in on his original track. He put 1200km on it I believe.
As fast as that click is in vid above I would guess the roller is out of the chain tensioner or something. One thing I have learned the hard way is if there is a issue and work was performed previous. Look at the work. Go backwards. 90% of time you will find the problem even if it really sucks ripping apart what you just did. I am in same situation with my blown fuse issue thats not blowing anymore. Cant trust sled so I need to start tearing it down looking for a short thats not there anymore. Well last thing I did was install the Winder stator. My $ is thats where my issue is. Just need to find the ambition and time to go backwards!
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
My 2017 SW LTX DX was like this whit ZERO milles!
The track he have on his sled right now have no "silent drive" inside
which means that the extrovert part of the track go deeper against the drivers....
- 16K
