I’ve always wanted some Titanium bolts. Absolutely a waste of money but I told myself I’d get a few for this build just because. I decided to get them for the chaincase, chaincase cover, speedo gear and brake caliper. The factory long chaincase bolts I think are 90mm in length, for my application they only need to be 85mm. All of the USA retailers only have 80mm and 90mm so I ordered from RaceTi in the UK. Excellent customer service, very quick to respond to emails and shipping only took about 2 weeks and was very reasonable. They were a lot less expensive than the USA sellers as well. Quality seems excellent and I’ll probably place another order for a few more. Can’t believe how light they feel in person.
Stock speedo gear and bolt, 60.96 grams
Counter bored speedo gear and Ti socket head bolt, 31.30 grams
Factory chaincase and cover bolts
Actually a pretty big difference, 0.33 lbs savings for just a few bolts plus they look good. These all have the dished heads, pictures just don’t show them.
Stock brake caliper
Unmodified Wilwood PS1 caliper
Bored some holes on the inside.
Bolted the two halves together and then ground the outside down to reduce weight but also increase clearance to the brake hub. Also counterbored the holes and bought shorter torx head Titanium bolts.
Modified caliper with Ti bolts. I also drilled out the M8 mounting holes and tapped them to M10x1.25 so I could use shorter M10 bolts without nuts protruding on the backside
Oilite bushing for the steering showed up today so I now have everything the finish up the steering post which I’ve been working on. Should have a good update on that in a couple days.
