Nikolai
Bodywork will just be 2 large pieces that overlap in the center so access to everything will be good.
Any more progress?
Nikolai
No. Took about 4 weeks to do a bunch of cage work on my Dad’s Kawasaki Teryx and then rebuilt his shocks so he could finish getting his rig ready for summer. Now I’m wrapping up some needed maintenance on the 660 Rhino (plow rig) and then I need to do my yearly full tear down on the RZR to prep it for another summer. I am going to try and get some work in on the sled too, I really want to get the oil tank finished.
Nikolai
Still alive. Kids got older, priorities changed, got them a 110 ATV and spent last winter building an off-road trailer to haul it behind my RZR so we could take it to our camping spots.
Nyper frame has been sitting in the jig slowly collecting surface rust. Going to have it sandblasted and then rattle can primer it to protect it and hope to get started on it again. Had to read thru this entire thread again just to remember what I had done.
Brotherdan
- Sep 8, 2017
- Belmont,maine
I’m So glad you gave us an updateYou have most of the hard stuff done!! , I’ve been wondering if you were still working on it,its definitely hard to find any extra time with children,work& family. I’ve got one of my sleds in pieces doing some upgrades & maintenance work,new track, seat etc& i find it’s difficult to find time to get in the shop& work on it especially with other hobbies,work, firewood etc,keep us posted its an awesome build & will be a really cool sled to ride when you get it finishedStill alive. Kids got older, priorities changed, got them a 110 ATV and spent last winter building an off-road trailer to haul it behind my RZR so we could take it to our camping spots.
Nikolai
My focus will be on painting the frame, getting it sitting on suspension and then I need to finish fabricating the oil tank and rear cooler so I can get it running. There’s a lot of work left…turbo needs rebuilt, make a charge tube, fuel tank, body panels, ect but after the oil tank all the remaining projects will be fairly simple.
This is the trailer I spent last winter building to haul the kids ATV.
Brotherdan
- Sep 8, 2017
- Belmont,maine
Thats cool, great job on the trailer,it looks factory built only much better quality,it fits the sidexside really well ,I need to build a trailer for my atv for hauling wood so every picture I see gives me more & different ideas,the mountains in the background aren’t so bad either!! Building memories with the kiddos love itMy focus will be on painting the frame, getting it sitting on suspension and then I need to finish fabricating the oil tank and rear cooler so I can get it running. There’s a lot of work left…turbo needs rebuilt, make a charge tube, fuel tank, body panels, ect but after the oil tank all the remaining projects will be fairly simple.
Nikolai
Going back a few years ago I had weighed the complete front suspension. I ended up buying titanium lower a-arm bolts and steel K nuts after that so I weighed everything again tonight. Trying to get some motivation building for myself.
5.40 lbs - lower a-arms w/ ball joints & collars
1.88 lbs - upper a-arms w/ bushings & rod ends
6.78 lbs - spindles w/ axles & spacers
4.42 lbs - shocks w/ bushings
1.02 lbs - bolts, nuts, washers (6mm bolts are steel)
Total front suspension weight for everything pictured 19.50 lbs.
When I weighed my Nytro like 10 years ago at 449 lbs it had the skinz front end with Ohlins shocks & Ti springs and from my notes I estimated that to be 27.21 lbs, so I’m 7.71 lbs lighter just in the front suspension alone.
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1981 ET340 "Frankenticer"
1982 SS540
1981 ET250 Mod Oval/Lemans Racer
Impressive!
Nikolai
Anyone know if the speed sensor has to be right by the gear? Will it read properly if it’s 0.75” away?
I want to put it here
Jori K
- Dec 12, 2021
- Finland
- Other
- apex 2006 GT
It could be everywhere, only whats matter is gap between sensor and gear.Anyone know if the speed sensor has to be right by the gear? Will it read properly if it’s 0.75” away?
Nikolai
The gap is what I’m wondering about. Will a 0.75” gap still read?
Jori K
- Dec 12, 2021
- Finland
- Other
- apex 2006 GT
Oh sorry, my english not perfect...missunderstanding. Gap should be close same as original.The gap is what I’m wondering about. Will a 0.75” gap still read?
DARKMAN
- Sep 27, 2023
- Harris, MN
- 2013 APEX SE
1982 SS540
It works by hall effect, so it has to be close. It will not work that far away. It all depends on the sensor, but generally a hall effect maximum gap is 0.100"
earthling
- Dec 1, 2017
- 2021 SRX
2006 ATTAK
a hall effect sensor is subject to the inverse square law so at double the distance it only has 1/4 the sensitivity. It has to be close to be effective.
- 215K
- 6K
- 120K
