JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
What do you guys think of my drive shaft? It's a 2017 that I bought Oct 2018 and put on 5500km last season. To me it seems like the bearing did spin but i'm not an expert. Bearing also doesn't really "feel" quite snug. Based on my calipers I have 1/128th clearance. Do I buy a new one or have someone weld and machine to a new bearing? I bought Loctite bearing mount and I have the BOP bearing lock but while I have it out I want to repair properly.
Appreciate the advice.
**Pictures coming, seems I can't just upload from my phone **
JayM
- Oct 29, 2018
- Pickering, ON
JayM
- Oct 29, 2018
- Pickering, ON
Sorry, this forum is so frustrating to try and upload pictures from a phone, hopefully the links work or someone can help fix it. Love this place just the media handling is iffy.
reduce images to 1024x768 with an app. Unless you have a latest iPhone update.
JayM
- Oct 29, 2018
- Pickering, ON
Yes just another app and twice the picsreduce images to 1024x768 with an app. Unless you have a latest iPhone update.
https://ty4stroke.com/threads/cell-phone-and-pc-image-help.150640/
With the new iPhone update it so easy. It reduces them for email and uploads. The phone makes them stupid big
I embedded the images in the post.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yes it has moved around some on the shaft. Hard to tell how loose it is but if you get the BOP expansion plug and install it I would bet it locks in place. If not you need a repair or new shaft. Your going to need the BOP lock with the new driveshaft anyway so see if it tightens up.
JayM
- Oct 29, 2018
- Pickering, ON
OK I will likely just roll with a new bearing, I got the BOP lock today and then green Loctite. I'm surprised the BOP lock actually expands that shaft, I hadn't really looked at how it worked before ordering lolYes it has moved around some on the shaft. Hard to tell how loose it is but if you get the BOP expansion plug and install it I would bet it locks in place. If not you need a repair or new shaft. Your going to need the BOP lock with the new driveshaft anyway so see if it tightens up.
Turboflash
- Mar 18, 2019
- Southern MN
The bearing is a 6009-2RS C3. The ID is 45 mm which is 1.77165". If I'm seeing the pic correctly, your caliper is showing 1 & 99/128 = 1.7734"
1.7734 - 1.7716 = .0018" difference. That is well beyond the tolerances bearings are made to (which are only a few .0001") so IMO, this bearing is toast. It has been worn by shaft spinning inside it.
The shaft pic shows the bearing journal is 1 & 49/64 = 1.7656". So, the bearing ID is 1.7734 and the shaft is 1.7656. That's .0078" clearance which is way too much. You'd want them to be within .001" of each other at the most! The shaft is banging around inside the bearing.
Bottom line IMO, both are toast. Need new shaft and new bearing (AND the wedgy thing from Travis at BOP).
Have fun!
Have fun!
JayM
- Oct 29, 2018
- Pickering, ON
Thank you!I embedded the images in the post.
JayM
- Oct 29, 2018
- Pickering, ON
Are new shafts from yamaha going to be better? Should I find a machine shop to weld and machine instead?The bearing is a 6009-2RS C3. The ID is 45 mm which is 1.77165". If I'm seeing the pic correctly, your caliper is showing 1 & 99/128 = 1.7734"
Have fun!
Pstn head
The brake rotor where it mates up to the inner race may also be worn.
Plus you might still have warranty?
- 6K
- 57K
