hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Is this the heating element powered all the time on this kit when running? Is it live with key on or does sled have to be running?
still testing my solution. No heated valve will be needed.
The updated ROV kit is a step in the correct direction. But dumping the vent hose into the air filter over the clutches is not a good solution. It will def. need a extended vent hose from the ROV and a catch can.
So there is no doubt we a looking for a permanent solution from you Travis!!!
rla1
- Jan 4, 2015
- saskatchewan
- 2017 sidewinder btx le,2021 mountain max le,2011 apex xtx,2012 arctic cat xf m8
I called the dealer that I got the rov kit from about missing instructions,they forgot to put them back in the box when checking to see that all parts of the kit was there.Do not know if I was suppose to get top page but what it says.
rla1
- Jan 4, 2015
- saskatchewan
After reading this page I called the dealer that resealed my oil tank in November (different dealer than I got the kit from)They said they just found out about this updated kit 2 weeks ago and that it was only to be available to dealers and that they could only order it when they put in a pre authorization with the affected sleds vin.The service manager told me to return kit where I purchased it from and bring my sled to them and they will put in updated kit.
rla1
- Jan 4, 2015
- saskatchewan
Also when I asked if it was a recall or a service bulletin they said no,that it was an update lol.
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I will be calling me dealer on Monday
snowbiscuit
From Minnesota and I just ordered the kit thru partzilla and got confirmation....looks like we will lose accessory plug in by oil tank(damn)....the other plug there doesn't look like it will work
Rtbo
- Feb 18, 2016
- N Syracuse
- 23 SRX
- N Syracuse
They make a splitter so you can turn it into 2 accessoriesFrom Minnesota and I just ordered the kit thru partzilla and got confirmation....looks like we will lose accessory plug in by oil tank(damn)....the other plug there doesn't look like it will work
snowbiscuit
snowbiscuit
I using the plug for heated helmet, so current draw could be a problem with splitter
Fast
- Sep 25, 2018
No Recall, i called yamaha asking get mine updated ,they said there is no recalls on my sled 2019 srx and if i brought it to my dealer and they say i need it yamaha will cover it, when asking the dealer they don't even know what a roll over valve is, brutalIs this a Canadian recall only? LOL
Fast
- Sep 25, 2018
Travis, let me know when yours is ready i'll take one.Is this the heating element powered all the time on this kit when running? Is it live with key on or does sled have to be running?
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Looks like I'll just keep the hose fix which has posed zero problems!No Recall, i called yamaha asking get mine updated ,they said there is no recalls on my sled 2019 srx and if i brought it to my dealer and they say i need it yamaha will cover it, when asking the dealer they don't even know what a roll over valve is, brutal
putz21
- Apr 15, 2013
- Tomahawk, WI
- '23 Sidewinder LTX LE w/EPS
‘19 Sidewinder LTX SE
Yes that is true,
In only 800 km on my sled I had a lot of oily water in my air box and at the bottom on panel under the belt.
Hate to say it but I just extended the hose to under the motor where it can leak onto the access door of the oil filter.
Any issue with this? My dealer just called and told me he put the new kit on mine and told me the hose running into the airbox is big! I'm not liking this idea. Did you buy a longer hose to run it down to the access door?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
No issues at all, I took the easy way and added a 5/8” barb connector and a piece of hose to the existing hose that went into the air box and just routed it under the engine compartment.Any issue with this? My dealer just called and told me he put the new kit on mine and told me the hose running into the airbox is big! I'm not liking this idea. Did you buy a longer hose to run it down to the access door?
The cleaner way would be to run a 5/8” id hose from the out of the valve to anywhere but inside the air box.
- 39K
- 50K
- 149K
