STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
I ended up throwing my old gear in for the rest of the season. I will research this bushing and address at next fall's teardown.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
New gear every 1500-2000 miles imo....dirt cheap 13$usd typical.
Some changes have been made to another common issue I saw at show, nice to see at least they are sorta half-#*$&@ paying attention.
Dan
Dan
RAMSOMAIR
and that change is.............?
putz21
- Apr 15, 2013
- Tomahawk, WI
- '25 Sidewinder XTX LE w/EPS
'23 Sidewinder LTX LE w/EPS
Dan
Where can you find the gear that cheap?
Drum roll please? Wait for it..and that change is.............?
RAMSOMAIR
waiting patiently.........well not that patient lol can you tell?
Exactly!! Retail on that gear is $52.99 and last time I ordered one it took 3 weeks.
DC5
My guess is heated roll over valve
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
heated ROV ?and that change is.............?
Mototown
- Sep 11, 2018
- Apex 40 th
I switched my oil from 70/90 amzoil synthetic to synthetic automatic trans fluid after my top bushing was down to the copper bushing after 800 miles . Just checked bushing still looks perfect after 800 miles trip . I'm heading out next week to upper Michigan for more miles will check after , but it's better than with 70/90 oil ...
RAMSOMAIR
I've been using using Royal Purple 75W140 in the SW for 9000kms and the Viper for 6600kms and both gears look great. I overfill the case a bit also.I switched my oil from 70/90 amzoil synthetic to synthetic automatic trans fluid after my top bushing was down to the copper bushing after 800 miles . Just checked bushing still looks perfect after 800 miles trip . I'm heading out next week to upper Michigan for more miles will check after , but it's better than with 70/90 oil ...
Mototown
- Sep 11, 2018
- Apex 40 th
Cat country had 22T with holes for around $40Exactly!! Retail on that gear is $52.99 and last time I ordered one it took 3 weeks.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I got this part number(1702-395) for $13.95 two seasons ago. I see they have gone up a tad but still cheaper then a tank of gas so well worth installing new every season IMO.
I know mine looks decent but will install new in fall.
Dan
Dan
RAMSOMAIR
Are you sure you will install a new one Dan? Sounds like its a keeper after the show??I got this part number(1702-395) for $13.95 two seasons ago. I see they have gone up a tad but still cheaper then a tank of gas so well worth installing new every season IMO.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
Honestly I just wish I liked the new sleds more....grrrrAre you sure you will install a new one Dan? Sounds like its a keeper after the show??
Dan
- 30K
