SumpBuster
- Jul 18, 2003
- Carlisle, NY .
- 18 sidewinder; 06 Apex RTX
Years ago I made an oilite bushing for my, ahem, Skiroule clutch! When they get warm they release some lube.Get the 1” long bearing $3.
I used this bearing and it lasted longer than the stock bearing.
I now don’t over tighten the chain and it’s lasting fine
660 bearing bronze sleeve bearing , 1” inside diameter, 1 1/8” outside diameter, 1” long
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
Yep oil lite is great for clutch bushings.Years ago I made an oilite bushing for my, ahem, Skiroule clutch! When they get warm they release some lube.
This is actually a harder material made for lubricated applications, 660 bronze. McMaster actually publishes the impact resistance of all the the different bearing materials.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Stock bushing isn't 1 in long.
Yea mine is 7/8in .873 but I have a Lathe.Stock bushing isn't 1 in long.
NYTurbo
- Sep 26, 2017
- Ottawa
- Sidewinder
Yeah, the one I measured was .900 long
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
Here’s my POS cat 22 top gear after 3000miles...
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Belt sander, hacksaw, file, lathe, multi-tool, sawzall, band saw, meat slicer, electric fillet knife... I’m sure you can figure it out.
Wow lucky they made the gears better than early years or yours would surely have Grenaded!Here’s my POS cat 22 top gear after 3000miles...
STAIN
- Feb 29, 2004
- Vermont
- 2024 Arctic Cat Riot 9000
- Vermont
So to revive this thread, I have been getting a vibration in my feet the past few rides. Went out today and it was worse. Took apart my chain case and the upper gear bushing is toast. 3k miles, 270 tune, chain finger tight and back 3/4 turn.
Has anyone else researched a better bushing?
STAIN
- Feb 29, 2004
- Vermont
- Vermont
High-Load Dry-Running Sleeve Bearings
Bronze-Backed PTFE
Plastic Bearings
with Steel Shell
A metal shell adds strength.
Bronze-backed PTFE bearings with steel shell combine high-load and high-speed capabilities. They resist swelling when exposed to moisture and are electrically conductive.
Note: Dynamic load capacity is the maximum load a bearing can withstand at a given shaft speed. If your application’s load and speed requirements are below the values listed, the bearing will work.
For technical drawings and 3-D models, click on a part number.
For
Housing ID Lg. Dynamic Radial
Load Capacity Temperature
Range, °F Each
Bronze-Backed PTFE Plastic Bearings with Steel Shell
For 1" Shaft Dia.
1 1/8" 1" 3,150 lbs. @ 60 rpm -320° to 530° 60695K7 $4.04
Comments???
Bronze-Backed PTFE
Plastic Bearings
with Steel Shell
For
Range, °F Each
For 1" Shaft Dia.
Comments???
Let me know what bushing you end up using, I would like to change the one the gear I have as well.
Crossfire12
- Feb 13, 2017
- New York Adirondacks
- 2010 Z1 Turbo ,2017 zr9000, F1100 turbo, 700 srx
- Sacandaga reservoir
Put new gear in cheap, seen them for $23
STAIN
- Feb 29, 2004
- Vermont
- Vermont
I know, been there. looking for something to last longer.Put new gear in cheap, seen them for $23
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
A good source informed me that yamaha is coming out with a fix for the upper gear issues. Believe it when i see it.
- 27K
