MartyV
- Mar 4, 2015
- Greenwood, ME
- 2015 Viper LTX SE
Had an idea while adjusting my headlight. Alot of heat coming from the dash vent area has anyone modded a fan to suck air out of the engine compartment? Maybe like a computer style fan mounted under the plastic vent? Don't know if it would help any since they sell a goggle holder that blocks it off. Just seeing if anyone's done it or thought about it.
stingray719
Reversed the fan wires on our red Viper to blow the air out instead of sucking steam in. Barn Of Parts is working on a hot air evacuation setup.
Yesterday was over 40 degF spent whole day doing 100mph+ pulls and riding on rivers. Very little snow on some stretches for miles. Just hard ice. With the reversed fan I never came close to overheating. Ran at 160F whenever I looked. I like the reverse fan. Doesnt help steam from powder unless fan is running so at high speed low load when engine is cool it wont help but soon as you stop fan kicks in and gets that steam out. Great idea. Heck on cold days all my buddies huddle around my radiator to warm there hands or unthaw a shield. Nice warm clean air to do it. Even better than the hot stinky exhaust coming out back of the Phazer,Nytro and other Yamahas! Great idea Stingray!
I do suggest using this tool or one like it for reversing the fan. You use the tube that has the biggest dia. Autozone or any auto store.
gpxsrx
Can you elaborate on the fan mod please.
Reverse the wires to make fan run in opposite direction?
Yes right at the fan plug. Pull the wires out of plug using the tool and put them back in reversed.
skidooslayer687
- Aug 22, 2013
- Almonte, Ont.
- 2014 Yamaha Sr Viper LTX SE
Also did fan reversal on mine, works pretty dam slick! Great mod IMO stingray!
Tricky Nick
Going Vertical
- Mar 23, 2014
- Eagle River, AK
- 2015 Viper MTX 162 Turbo
Back up sled AC M7
Something like this? This one is meant to be installed on the clutch side of an Arctic cat but I would imagine you could install it anywhere to suit your needsHad an idea while adjusting my headlight. Alot of heat coming from the dash vent area has anyone modded a fan to suck air out of the engine compartment? Maybe like a computer style fan mounted under the plastic vent? Don't know if it would help any since they sell a goggle holder that blocks it off. Just seeing if anyone's done it or thought about it.
https://www.mtntkperformance.com/blow-hole/2014-15-arctic-cat-pro-climb-blow-hole
MartyV
- Mar 4, 2015
- Greenwood, ME
- 2015 Viper LTX SE
Did the reverse fan have any effect on the intake temp?
stingray719
Measuring it without a controlled environment is near impossible. But think of this, now the fan blows air out of the hood instead of DIRECTLY into the air box opening.
stingray719
That will work well, but I took a small screwdriver and gouged out the very small spline in the connector so I could turn it 180 degrees and plug back in.....just in case I wanted to reverse the process on the mountain. But, as it has worked flawlessly for me I cannot imagine putting it back.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
We will soon be offering a plug and play pigtail to revers the fan for those that don't want to tamper with with wiring
yamadoo
- Jun 3, 2003
10 Vector LTX Blue 9kmiles
11 Venture GT 4k miles
86 SnoScoot(2) for grand kids
That is great thinking. If I understand you just created a groove so can be installed either direction. MarkThat will work well, but I took a small screwdriver and gouged out the very small spline in the connector so I could turn it 180 degrees and plug back in.....just in case I wanted to reverse the process on the mountain. But, as it has worked flawlessly for me I cannot imagine putting it back.
stingray719
Close, I took a small flat blade screwdriver and took out the spline.That is great thinking. If I understand you just created a groove so can be installed either direction. Mark
yamadoo
- Jun 3, 2003
Oh even better I am learning to read. LOLClose, I took a small flat blade screwdriver and took out the spline.
Allan
I did the fan reverse just as you described above this evening. Started it up and let the fan cut in man there is a lot of hot air coming out of there.
