walter
- Nov 22, 2014
- Linwood, MN
- 2015 Viper LTX LE Turbo
2009 Nytro XTX
2002 SRX 700
Have not replaced shaft yet... Waiting for the riding season to be done then I will start my summer upgrades.Did you put the bigger shaft in?
If its bent get it out before next ride. It gets very ugly when it snaps and could be dangerous. Wish I would have had a warning that mine was going.
walter
- Nov 22, 2014
- Linwood, MN
2009 Nytro XTX
2002 SRX 700
I think I'm done riding for the year now.... not looking good with all the 50s and 60s in our forecast.. been a crappy winter
Chewy
- Oct 2, 2015
- Arctic Cat XF7000
Is the RR shaft a direct replacement? Or do you need to mod other parts to make it fit?
09nytro
It's a replacement part , no other mods to do ....Is the RR shaft a direct replacement? Or do you need to mod other parts to make it fit?
jeffgilbert
- Dec 17, 2007
- Newfoundland
- 2019 Sidewinder BTX LE
I have found that there is a nice few small differences in the rr/le skid when was working on mine I am glad I got it, I give mine a good going over.
Michael Geil
- Jan 7, 2016
- western new york
- 2016 yamaha viper mpi turbo
the 14 viper I had front skid shock fail twice ...really surprised that my shaft didnt break..shock would fail at around 2300 miles each seasonAll Viper Owners take a look at your front arm cross shaft on your rear skid. Especially if you are riding these sled super aggressively over heavy rutted trail trash. It looks like the shaft is shearing off right at the end of the bolt and the bushing support. It looks as if most of the damage is done to the shaft and the tunnel once it lets go.
View attachment 106821 View attachment 106822 View attachment 106823 View attachment 106824
The bolt and collar should not be the same length so the stress on the shaft is not in the same place... thats my take on it.
See the skid looks fine.
Water in it I bet.the 14 viper I had front skid shock fail twice ...really surprised that my shaft didnt break..shock would fail at around 2300 miles each season
Michael Geil
- Jan 7, 2016
- western new york
im not sure ...one unscrewed lost oil the other snapped at top of shaft after oil loss..think in both cases it over heated shock on ruff trails..shocks were good on 16 viper motor not so muchWater in it I bet.
Are you riding PA trails? That will do it! lolim not sure ...one unscrewed lost oil the other snapped at top of shaft after oil loss..think in both cases it over heated shock on ruff trails..shocks were good on 16 viper motor not so much
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Is there a difference in torque specs on the slider axle from stock to the .765 one ?
Good question. Never thought of that. I assume no since its same dia. Bolt. Will check manual though.Is there a difference in torque specs on the slider axle from stock to the .765 one ?
55 ft lbs and Blue Loctite could not find any different specs in AC or Yamaha Service manual.
swampcat
- Mar 17, 2014
- N. E. Wi.
- 2020 S W LTX-GT
Thanks Steve, I could NOT find that spec in my 2015 manual.
machzrobbie
I had mine break a couple of weekends ago, replaced it with a high mile used one because it's back ordered here in Canada and that broke again this weekend. Both broke on rough trails and the sled bottomed out a number of times. Was able to ride home slowly both times.
- 12K
