Redbeard
- Oct 14, 2011
- IN
- 2012 Apex, 136 M20, PB80
2008 Vector, 136 M20, PB80
Front end is disassembled, cleaned up and new A-arm bulkhead bushing are installed. I pulled the relay arms loose from the bulkhead to check the bushings and re-grease everything...all looks good there! I am, however; replacing all tie rod ends in the front end, so a ski alignment will be in order once everything is buttoned up.
The factory ski's, spindles, aftermarket arms, torsion rod, etc are all getting replaced. Not sure if I want to re-use my Pilot 6.9's on this sled, or use the new set of USI Triple threat ski's I have on hand?
Stay tuned!
Stay tuned!
Redbeard
- Oct 14, 2011
- IN
It's starting to look like a sled again! The right and left side is re-assembled and the Bulkhead saver is in place. I just need to install the new torsion bar, sway links and tie rods, then align the ski's.
For now, I've decided to put the stock ski's from my Apex on this sled. They've never even been on the snow yet!
superfan75
- Sep 12, 2013
- West Topsham Vermont
- RX Warrior
That is going to be one kick #*$&@ Warrior !!
Redbeard
- Oct 14, 2011
- IN
Finally found time to align the track and skis's yesterday. I use a Yamaha specific tool that locks the relay arms in dead center for ski alignment (Yamaha # YS-01487). The outer side panels need installed and this sled will be ready for a rip......once my TY ID decal is on the windshield of course!
Here's some pics:
Here's some pics:
drew24
- Mar 13, 2015
- NW Indiana
- 99 SRX 700/02 viper
Nice build. Looks awesome.
DGZRT
- Feb 23, 2006
- Stevens Point Wisconsin
Excellent write up and build !!! Nice picture's . Would you have a write up on your Carb syncing rack and how to hook them up? I have had my Vectors done by the dealer but have never tried it my self.
I have ordered a carb syncing tool but the directions are not very informative.
Thanks Dan
Thanks Dan
superfan75
- Sep 12, 2013
- RX Warrior
That tool to set the steering exactly straight is cool. That sled is going to be sweeeeet !!
Redbeard
- Oct 14, 2011
- IN
Would you have a write up on your Carb syncing rack and how to hook them up? I have had my Vectors done by the dealer but have never tried it my self. I have ordered a carb syncing tool but the directions are not very informative.
I use a motion Pro sync tool on my 973 Vector and just did my first 4 cylinder a few weeks ago. Everyone has their own method, but I use a home made gas can to gravity feed fuel directly to the carbs. This allows me to unhook the vacuum lines to the fuel pumps and have all cylinders hooked to the gauge at once. The fuel can is also a great way to prime your carbs after the sled has been sitting all summer.
Here's a pretty cool video on how to use and correctly calibrate the sync tool before each use:
Hope this helps!
DGZRT
- Feb 23, 2006
Thanks for the help!!
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
View attachment 114043 View attachment 114044 View attachment 114045 View attachment 114046 View attachment 114047
Was that right bulkhead reworked? Looks like a lot of material between the ears.
Redbeard
- Oct 14, 2011
- IN
It sure was! Everything lines up pretty good though. I'm going to run it this way for now, but I may consider swapping out the bulkhead during phase three.Was that right bulkhead reworked?
Redbeard
- Oct 14, 2011
- IN
I took a picture of a spare carb rack I have for reference. The 3 and 4 cylinder sled's have a master carb that you sync the remaining carbs to. There are sync screws (not the idle adjustment screw) in between each carb. I would recommend adjusting all the pilot screws equally before sync and make sure the sled is warmed up! I think you can use any of the vacuum ports to initially calibrate the meter, but I use the master carb vacuum port...just because.Thanks for the help!!
3 cylinder:
1) sync #2 with #3
2) sync #1 with #3
4 cylinder:
1) sync #3 with #2
2) sync #4 with #2
3) sync #1 with #2
3 cylinder:
1) sync #2 with #3
2) sync #1 with #3
4 cylinder:
1) sync #3 with #2
2) sync #4 with #2
3) sync #1 with #2
View attachment 114513 View attachment 114514
I am so impressed with your thoroughness.. great job!!
superfan75
- Sep 12, 2013
- RX Warrior
Your write up makes me wish I did my own last winter. The shop I took it to only charged me like $20 so I didn't bother trying it. So I figured for that price I'd let them do it.
Redbeard
- Oct 14, 2011
- IN
We received a skiff of snow and I finally got to try 'er out! All seems well and she pulls like a freight train! I also blew the dust off the Vmax4 and brand B!
I have one more thing I'm going to do before I get serious about riding this Warrior...stay tuned!
- 22K
