Asphalt Results 2005
What you have to go in to tech seperately from racing????
They have an early tech session, so things aren't so crowded on our practice day. I like to get 'er done right away, in case there is something I missed, or fubbed on, where I have time to make a change.
Also, I can go and park in my pit stall, and start running as soon as the track opens. I will need a lot of practic, as this suspension needs to be dialed in.
Buster would you mind sharing the jetting and clutching you are running? I just finished installing a CPR turbo and will be setting it up for asphalt.
Alright, More Yami sleds!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I"ll be running this summer too. I'm just starting out so I'm keeping track of what I go through and what I need to get going. I'll keep everyone posted as I'm sure it will be good info for anyone interested next year.
I'll be running my bigbore n20 SRX in brainerd and maybe moorhead this year.
Congradulation's Terry,What a way to start out the year in the finals right away!
Thanks Ryan! Glad you could come and help out.
Alright, here we go!
2005
4/16/05 - High of 62 degrees, with a max. humidity of 40%, Headwind of 15-20mph
(Test and tune)
1st run - New Wahl suspension and 10 5/8 track, needed a lot of tuning, but the Wahl is easy to tune.
1.662 60ft. - 7.310 1/8mile @ 91.447mph - 11.719 1/4mile @ 108.256mph
2nd run - loosened track, lowered front torque arm, and tightened scissor spring.
1.679 60ft. - 7.182 1/8mile @ 91.461mph - 11.599 1/4mile @ 107.919mph
3rd run - tightened track, lowered front torque arm, and tightened scissor spring. Pulled toward gaurdrail.
1.657 60ft. - 7.178 1/8mile @ 90.716mph - 11.672 1/4mile @ 105.726mph
4th run - tightened spring.
1.576 60ft. - 7.135 1/8mile @ 91.434mph - 11.587 1/4mile @ 106.412mph
5th run - bigger burnout, and tightened spring.
1.535 60ft. - 7.060 1/8mile @ 92.285mph - 11.447 1/4mile @ 108.416mph
4/17/05 - Season Opener - Pro Bike/Sled Runner-up!
No headwind, and temps got to a max. of 72 degrees, and 58% humidity
1st time run - new belt, otherwise same as Saturday test
1.502 60ft. - 6.943 1/8mile @ 93.831mph - 11.237 1/4mile @ 111.135mph
2nd time run - same setup (spun)
1.587 60ft. - 7.023 1/8mile @ 93.499mph - 11.353 1/4mile @ 110.489mph
1st round - same setup (Dial in - 11.23)
1.502 60ft. - 7.002 1/8mile @ 92.602mph - 11.400 1/4mile @ 103.432mph
Won round 1 (Hit the brakes, so I wouldn't breakout)
2nd round - same setup (Dial in - 11.28 )
1.516 60ft. - 7.038 1/8mile @ 92.121mph - 11.422 1/4mile @ 108.621mph
Won round 2 (other guy redlighted)
3rd round - Tightened track (Dial in - 11.44)
1.523 60ft. - 7.011 1/8mile @ 93.075mph - 11.341 1/4mile @ 109.960mph
Won 3rd round (other guy redlighted)
4th round - no change
1.626 60ft. - 7.034 1/8mile @ 94.609mph - 11.339 1/4mile @ 111.195mph
Won round 4 (Got the BYE run)
5th and Final round - (Dial in - 11.28 )
1.502 60ft. - 6.987 1/8mile @ 93.099mph - 11.332 1/4mile @ 109.619mph
Lost Final - Both of us were off the throttle at the end, so we wouldn't break out.
Well, what can I say, 2 Yamahas in the Final round. 2005 RX1, and a Yamaha V-max bike.
:yam:
Thanks guys!
Mark another win for Yamaha!
Great job Terry!
Terry, did you change something between these rounds. 60 is much better in last round but look at MPH and ET at the end, better MPH and about the same ET but your 60 ft was alot better in last round. Did you take some weight out in the middle of the weight for the last round?
Looks like fun. Terry good luck with the season. I hope you take 1st this year.
Let us all know ehn you make some for fun NOS passes and what your times are.
Way to go Terry!!! Are you still running stock gearing or did you get that 26 in?
