snowdust
- Oct 26, 2003
- Northern Illinois
- Sidewinder
Installed yesterday on a used shaft that was in good shape. Installed all the way in as well and had to go to 50lb. to get it to where it was hard to get off by hand. Rotor is loose.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Was at my dealer on Friday to pick something up, they have a bin full of old drive shafts. They are replacing them like hot cakes. Others that aren’t under warranty they are loctiting them back on with red loctite.
sound like an epidemic to me....
Ms
Ms
alain459
- Apr 2, 2014
- shawinigan
- viper rtx dx 2015
Installed yesterday on a used shaft that was in good shape. Installed all the way in as well and had to go to 50lb. to get it to where it was hard to get off by hand. Rotor is loose.![]()
alain459
- Apr 2, 2014
- shawinigan
- viper rtx dx 2015
x2 but40 lbs of torque
Turboflash
- Mar 18, 2019
- Southern MN
Was at my Cat dealer yesterday. He told me track shafts are back-ordered 4 weeks. He told me his contact at Cat said there are at least 700 on back order now. Yikes!Was at my dealer on Friday to pick something up, they have a bin full of old drive shafts. They are replacing them like hot cakes. Others that aren’t under warranty they are loctiting them back on with red loctite.
Ms
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
Been shopping around for a sidewinder, I mentioned this problem to a few of the bigger dealers and shocking to hear they never heard of this problem lol..Was at my dealer on Friday to pick something up, they have a bin full of old drive shafts. They are replacing them like hot cakes. Others that aren’t under warranty they are loctiting them back on with red loctite.
Ms
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Finally got around to installing mine today. Cleaned the inside of the shaft, tightened the driveshaft saver so it was biting, tapped it in flush and brought it up to 43 ft lbs. Disc had play - all looked good.
Sled is all together so I have to guess this torque is enough to expand the shaft. Had it apart this summer so I had a sense of how much play existed.
Here is the question - how many have run the sled on a stand and watched the caliper assembly or disc. I noticed caliper assembly moves slightly with the rotation of the shaft. You cant feel it when you place your hand on the side of the tunnel and it doesn't transfer to the handlebars, but it looks like the bearing is not true on the shaft. Has anyone else experienced this?
MS
MS
That’s what Travis found and is reason he didn’t want disc locked solid.Finally got around to installing mine today. Cleaned the inside of the shaft, tightened the driveshaft saver so it was biting, tapped it in flush and brought it up to 43 ft lbs. Disc had play - all looked good.
MS
Turboflash
- Mar 18, 2019
- Southern MN
Didn't notice anything like that on the 3 I put in. Any chance your track shaft isn't straight?Finally got around to installing mine today. Cleaned the inside of the shaft, tightened the driveshaft saver so it was biting, tapped it in flush and brought it up to 43 ft lbs. Disc had play - all looked good.
MS
eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
BDX/SSI makes complete shaft assemblies that are lighter for $279. Might be an option for some instead of waiting until spring for a Yamaha one..
number1kyster
- Dec 10, 2004
- Vermont
- 2018 SW RTX SE
Didn't a member install one of these shafts and have it break on the first ride?
Yes the aluminum shaft. Get steel one. Or was that Jackshaft?Didn't a member install one of these shafts and have it break on the first ride?
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
Does anyone have any experience with the Driveshaft Hurricane has?
Does it have a closer bearing tolerance?
FrozenTows4
- Nov 6, 2014
- Brainerd Minnesota
- 2014 XF7000 Sold
2017 ZR6000RS
2018 ZR6000 El Tigre
- YOUTUBE
- FrozenTows1
What torque for those 3?
Mine landed at 32ftlbs on both sleds.
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
Quite possible. Although I don't know a specific event that would have damaged it.
To the other comment, disc still has play so its not locked.
MS
MS
- 8K
- 7K
