YamaSpark
- Sep 21, 2017
- Greenfield, Minnesota
- 2016 SR VIPER S-TX 137 DX
I had my wedge installed with the flats out & it took 35 ft. lbs to snug up the bearing. My disc still had plenty of play, but I decided to try it with the wedge all of the way in anyway. Now it needs only 25 ft. lbs to do the trick. Nice! I'm leaving it all in!!
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
New shaft? Old? New bearing?I had my wedge installed with the flats out & it took 35 ft. lbs to snug up the bearing. My disc still had plenty of play, but I decided to try it with the wedge all of the way in anyway. Now it needs only 25 ft. lbs to do the trick. Nice! I'm leaving it all in!!
YamaSpark
- Sep 21, 2017
Shaft with 1000 miles and slight wear, new bearing.New shaft? Old? New bearing?
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Thanks for info.Shaft with 1000 miles and slight wear, new bearing.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Can the wedgie be installed with the axle in the sled ?
if it can then I would have the dealer install new bearings and old axle , and leave the cover off the chaincase , so I can add the wdgie , close the chaincase and fill the oil .
RAMSOMAIR
Wedge is installed on the brake side of axle or opposite of chaincase.
Q. Arrius
- Feb 6, 2015
- Indiana, (central)
- '17 Sidewinder LTX LE (red)
'12 Apex SE (black)
'12 Arctic Cat F800 snopro (129, orange)
'15 SRX 120 (blue)
''15 S.Doo Renegade XRS (Ronald McDonald colors)
I could really use some help:
I ordered a new NACHI bearing. With the new bearing, and my worn shaft....the difference will be .55mm.
With the BoP expander and green bearing compound.....will I be ok?
I have a warranty....but with shafts back ordered, I’m afraid I’ll be waiting into Jan.
Opinions, thoughts?
Q. Arrius
Opinions, thoughts?
Q. Arrius
RAMSOMAIR
There is no way that the wedge and retaining compound will take up that difference! I know I have about the same wear. See my pic in this thread. My sled is under warranty also but I’m doing the work myself. I ordered an axle assembly from Cycle Parts Nation and tracing says I Wil receive tomorrow. 5 days since I ordered. There are shafts around!
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Sledding deprived brain cramp !Wedge is installed on the brake side of axle or opposite of chaincase.
Turboflash
- Mar 18, 2019
- Southern MN
No way with .55mm. Gonna need either or both new shaft and/or new bearing.
SPM
- Nov 18, 2018
- so. mn
- 2018 Sidewinder L-TX LE
Shafts are available and you're going to need one with that much wear on yours. My dealer had mine in less than a week under warranty.I could really use some help:
Opinions, thoughts?
Q. Arrius
I'm replacing the shaft myself at home and was glad to hear I didn't have to haul my dismantled sled to the dealer.
RAMSOMAIR
That was my issue also!Shafts are available and you're going to need one with that much wear on yours. My dealer had mine in less than a week under warranty.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
Why can't we put two drive shaft wedgey things in our driveshaft for both bearings? Has anyone tried it yet?
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
The other end in the chaincase is "blocked" but I'm not too sure if that's just a plug that can easily be removed or not.
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
I bet it can be easily done as long as the inside diameter is the same.
- 10K
- 8K
