SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
My secondary is 37/42 gray secondary spring wrapped 0/1. D&D set up. I know, I know, nobody running D&D set up but I tried the stock secondary wrapped 3/3 and it sucked compared to this set up. Sled extremely lazy. Tested same day, same conditions and back to back. 37/42 pulls stupid but I believe D&D is now running 35/39.clutch setup?
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Before checking your offset, make sure you all are checking to see if your snub shaft pushed in. This has happened with a lot of belt blowers.
Take a mirror and look between the engine and your primary clutch. You should see a visual gap of a 1/16" between the heads of the bolts that hold your snub shaft block on the engine and your primary clutch.
A lot of these are coming in from belt blower Sidewinders and Thunder-Cat. This majorly changes the offset distance.
"The fix" The primary clutch must be removed and the housing block that holds the snub shaft can be removed with a bolt and slide hammer. Once removed, the snub shaft needs to be pressed out, cleaned and re-installed with green loctite, pressing the snub shaft back in. (Note, never rotate clutch clockwise while mounted to engine. It could possibly just timing because of the hydraulic timing chain adjuster.)
SideHogger
- Apr 16, 2016
- upstate ny
I will be checking this today. Thank you.
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
SideHogger
- Apr 16, 2016
- upstate ny
What are you suggesting for offset?Everyone should be![]()
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
View attachment 154251 View attachment 154252 View attachment 154253 View attachment 154254
mine had moved almost 3mm whitout touching the back of the clutch .
Green locktight OD AND ID....
57:5/58:5 offset should put you in the ballpark
- Nov 11, 2016
- Cedarville, MI
- Cedarville, MI
Thunder Products Clutching sees the best belt life with an offset at 59mm. ***This is what we are seeing as the best, but every sled is different***
SideHogger
- Apr 16, 2016
- upstate ny
Thank you.Thunder Products Clutching sees the best belt life with an offset at 59mm. ***This is what we are seeing as the best, but every sled is different***
Fast
- Sep 25, 2018
I tried that asked the dealer to set mine to 58.1 and he told me it's ok at 59.1 the best he could get with no washer behind the secondary (58.1-61.1 is ok with yamaha i guess), 19 srxThe machine is not built correctly at the artic cat factory if it cannot achieve the full range of offset in Yamaha's spec of 58.1 to 61.1.
Take it back to dealer for warranty and tell them you want to set your offset at 58.1 and it won't meet that spec with no shims on shaft.
See what Yamaha says about this.
Maybe someone at the factory is putting a bolt in the stub shaft and hitting it with a hammer driving in inward.............
Fast
- Sep 25, 2018
Is that a yamaha grey or D&D do you have any specs on it?My secondary is 37/42 gray secondary spring wrapped 0/1. D&D set up. I know, I know, nobody running D&D set up but I tried the stock secondary wrapped 3/3 and it sucked compared to this set up. Sled extremely lazy. Tested same day, same conditions and back to back. 37/42 pulls stupid but I believe D&D is now running 35/39.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
It’s in between the cat red/white and the cat green spring.
SideHogger
- Apr 16, 2016
- upstate ny
D&D grey. I have no idea the specs on it. Clutchmaster on top of it though!Is that a yamaha grey or D&D do you have any specs on it?
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Slightly less than the EPI purple, could be a good spring for me to try, with the XS belt.
SideHogger
- Apr 16, 2016
- upstate ny
Byam, do you have any pictures after you redid the bearing? Cause I have a .040 gap on mine.mine had moved almost 3mm whitout touching the back of the clutch .
Byam
- Apr 23, 2015
- En Motoneige
- SW2017
custom
- 12K
