jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
Replaceable tips.
Scratchers..
Been running these for two seasons.. One sled has them mounted through the bolts that hold skid in.. The other sled I mounted them to the bracket.. IT DOES NOT matter which way,, No issues with rounded out holes. These things work awesome.. Just one down is enough, and the snow gets kicked up onto the track and then shot up and around to tunnel cooler.
Scratchers..
Ski-Doo New OEM Snowmobile Tunnel Ice Scratchers Replaceable Tips, 860201516
Buy Ski-Doo New OEM Snowmobile Tunnel Ice Scratchers Replaceable Tips, 860201516 at Amazon. Customer reviews and photos may be available to help you make the right purchase decision!
www.amazon.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
BRP Ice Scratchers
I thought about this also.. Actually I was really eyeing up the LOWER bolt hole.. Im going with the original way through the mounting bolt.. Im assuming this person drilled a hole through the bracket? Looks like the coil is close to rubbing side bracket while scratchers are in up position?
ty4stroke.com
pics mounted both ways. Page 7
shawnj
Thanks for the info. I did try looking for that part number but think its discontinued maybe , might be a new style or part number they are going by now. I checked BRP site and there are several model numbers to choose from ,,,Replaceable tips.
Scratchers..
Buy Ski-Doo New OEM Snowmobile Tunnel Ice Scratchers Replaceable Tips, 860201516 at Amazon. Customer reviews and photos may be available to help you make the right purchase decision!www.amazon.com
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Yea that part number was possibly replaced or whatever.. I posted exactly what I ordered off amazon in late 2021 I think.. I ordered two sets.. The tips don't last that long, but just one scratcher down works great.. I have another buddy that runs these also we installed before last year.. Zero issues.. Just replace the tips.. So 3 sleds and a 4th this season on a 2022 GTX that he got late last season, and just getting miles on this year..Thanks for the info. I did try looking for that part number but think its discontinued maybe , might be a new style or part number they are going by now. I checked BRP site and there are several model numbers to choose from ,,,
shawnj
That's excellent info thank you. I just called local BRP dealer, that number does show up on their system still but also has a superseded part # of 860202387 which is the same but bit more money. Thanks again for the info!Yea that part number was possibly replaced or whatever.. I posted exactly what I ordered off amazon in late 2021 I think.. I ordered two sets.. The tips don't last that long, but just one scratcher down works great.. I have another buddy that runs these also we installed before last year.. Zero issues.. Just replace the tips.. So 3 sleds and a 4th this season on a 2022 GTX that he got late last season, and just getting miles on this year..
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
Anytime. Pm me if you need anything on install if you go this route..That's excellent info thank you. I just called local BRP dealer, that number does show up on their system still but also has a superseded part # of 860202387 which is the same but bit more money. Thanks again for the info!
shawnj
I think the reason they showed up unavailable for me was because of your original link and they don’t have them but a stand alone Amazon search does show them available. Also shows the 860202837’s available as well (which was the superseded number). I see I can purchase either for same price. Just trying to figure out which I should be ordering lol.Anytime. Pm me if you need anything on install if you go this route..
The local dealer is back ordered for both sets and no available date.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
The superseded number comes with longer bolts for the G4. They are to long so I just got new bolts.
shawnj
Ahh ok. Same length scratchers pretty much do you know?The superseded number comes with longer bolts for the G4. They are to long so I just got new bolts.
Looks like I can get either set. (Maybe).
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
Ya same length from what I could tell. It now comes with both sets of brackets for G4 slim body mxz 129" vs wide body 137". You only need the small brackets they use on wide body.
shawnj
Okay thanks for that info. I might see if I can get the 860201516’s in the chance the bolt might work. If not, I will pick another up.Ya same length from what I could tell. It now comes with both sets of brackets for G4 slim body mxz 129" vs wide body 137". You only need the small brackets they use on wide body.
Phatboyc
- Apr 2, 2007
- Ottawa, Ontario
- 2022 Sidewinder
You'll love them. Can put them down without getting off of sled.
Dash Riprock
How did you mount it to the bracket? Do you have any pictures? Thank in advance!Replaceable tips.
Scratchers..
- 13K
