Another pic from my other sled...
Those will attack me.. I will have my pants ripped for sure.. but thats just me.
68gmc
Really....
Really....
Yep.. I will be talking to someone and run into the stupid thing sticking out like a broken fence wire.
XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
I have these on my 1200 Doo. How did you mount them? Did you drill a hole in the bracket that hangs down?Brp scratchers. Lots of spring down pressure, provides plenty of ice chips and snow for cooling and slides and can reverse without damage and stow easily when not in use!
Deeppow16
- Oct 19, 2015
- Montrose, Minnesota
- 2016 Arctic Cat M8000
2002 Polaris 600 XCSP (Sold)
I like the cable ones as you can back up without breaking them. Just put them down and forget about it. I use the dura cables and have yet to replace the tips that are now 4 years old and still show little wear. Very nice product IMO.
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Just ordered the ski mounted ice scratchers and a seat screw from BOP.
2 weeks since I have been out on my sled. Sled had been in the shop and I have been out West working!
Trail reports are fabulous and I have some planned time off during the next 2 weeks.
So if the trails get too hard this year I can keep on riding without overheating and that will be COOL!
Sevey
- Feb 15, 2011
- Collingwood, ON
- www.ty4stroke.com
- 2018 Sidewinder RTX
Do you find they produce enough dust being located so far back?
MS
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
I prefer the flexible cable ones like Dan has. I have used them on a vector and apex. You don't have to worry about going in reverse and forgetting they're down. I don't have any on my sidewinder yet, but would go with these again if I do. The only negative I experienced was the mounting bolt loosening at times. Benefits outweighed this irritation. Mine were mounted on the skid about 1/2 way back.
I experienced the loosing part this past weekend. My right side one mounted on the skid was there when we took off after our 2nd stop then went about 20 miles and it twas gone. Guess I'll have to order another set to get the right side one!
This is why I chose the Trail Blizzer from Qualipieces. The unique mounting system, wont allow it to loosen.
Dan
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
BRP Renegade mxz 800
Raised it up...
Sent from my SM-T705W using Tapatalk
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
I have read hundreds and hundreds of reviews over the yrs....and just about every single one ends up saying the ski mounted cool better then skid mounted, lots of guys who have swapped them out over the yrs.
For me I hate something that is hanging on my sled....so the fact you can buy these very small, lightweight cables....and bolt them on in minutes when needed is exactly how I like to do things. Scratchers are something I might need once or twice a season, not something I want to have permanently attached every ride when there is no need.
Most times you know full well ahead of time which days you will need them, and the unexpected days you just pull them out of your tunnel bag and bolt them on.
Dan
Dan
GlennM
- Jan 25, 2017
- Quebec
- Sidewinder ltx-le
SR-Viper 2015
Apex ltx 40th
Lol I never look at them when I ride but I know they're there!I have read hundreds and hundreds of reviews over the yrs....and just about every single one ends up saying the ski mounted cool better then skid mounted, lots of guys who have swapped them out over the yrs.
Dan
SAB1
- Mar 1, 2011
- Tuftonboro NH
- 2017 Sidewinder LTX SE
2010 Vector GT
2006 Apex
I have Travis' setup on my Apex and like it. The good thing about it is if you were to hit something it will break away from the ski. I have not had an issue with duraflex scratchers loosening up as others have mentioned. I'm putting the same on the winder.
SuperTurbo
They work perfecYou could be right since I have yet to need them.
No worries.. I have lots of miles mounted in the same spot on pilots in lots of conditions, they shoot the sh*t where needed and work flawless.Joe that spot worries me....the Pilots are vulnerable in the few inches ahead of the spindle on the vertical structures. I have seen pilots bend at this point if a heavy dip is hit. With those holes drilled there, you really are asking for trouble there if a certain situation arises. Be careful as those may fold right up.
Dan
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
They work perfec
lol , you missed the point. I have SEEN first hand pilots fold up there. That is the most vulnerable point on a pilot that needs strength. Not a good idea to drill holes there at all.
XP123
- Dec 25, 2016
- Chautauqua NY
I never thought about that Dan but now that it's there I will go with it. If you look at how I mounted them I have a fully threaded bolt running the whole distance across with nuts and washers tightened on both sides. Maybe they will add some strength where I drilled the holes? I also remember when the Pilots folded in that area but if I remember right it was on the original 5.7 Pilots. Doo redesigned them after that and they don't do it anymore.lol , you missed the point. I have SEEN first hand pilots fold up there. That is the most vulnerable point on a pilot that needs strength. Not a good idea to drill holes there at all.
