PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
- 2021 Sidewinder SRX
track will turn easy and then get harder then easy and hard....
That’s exactly what it does. It doesn’t click every time. When turning by hand, i can turn it half a revolution with no clicking, then it starts again. Especially when changing direction
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Did you change your sliders? Did you cut them too long or at an angle?
1200 miles on the original slides
jagger2014
- May 1, 2015
- newfoundland
- 2018 rtx se
take it for a 5 min rip …
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Will do. In the truck for next 4 hours to Timiskaming Quebec. Headed to Val’dor tomorrow.
Thanks guys. Really appreciate your thoughts !!
If it does turn out to be those extroverts I would get rid of those right away. Junk. I can turn my track on RR and Viper with two fingers. Introverts.
Good luck! I hope these guys are right.Will do. In the truck for next 4 hours to Timiskaming Quebec. Headed to Val’dor tomorrow.
Doowithblue
- Mar 17, 2016
- Waterloo ON
- 07 Mach z x (sold)
18- RTX LE
Brent just work on it in the trailer while Sims drives! Lol.Crossfire12
- Feb 13, 2017
- New York Adirondacks
- Sacandaga reservoir
I just checked my 137 inch and a quarter, I have every other window clipped not everyone. Check your old track how is it clipped? I have same drivers. I can’t see good do you have every hole clipped?
WinderFab
- Mar 1, 2009
- Woodbridge, ON
- 2020 Sidewinder Ltx GT
X2In the first video the sound is way slower than the track is turning. I am thinking chaincase. You guys hearing the same thing I am? That is not normal.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Srx oem full clip.
Doowithblue
- Mar 17, 2016
- Waterloo ON
18- RTX LE
Brent did you use different brand of studs on this one vs the original 1"?
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Both tracks are fully clipped
PowderFalcon
Pinnin' it!
- Jan 29, 2007
- Drumbo, ON
Same studs. Gold diggers. Different length and pattern
Have a GREAT trip...keep us posted
murdered141
Snow Punisher
- Nov 24, 2015
- U.P Michigan
I would crack the chain case and make sure everything is in order before going for a ride just to rule that out.
- 18K
