Jori K
- Dec 12, 2021
- Finland
- Other
- apex 2006 GT
How about alumin
How about aluminium rivet nuts and alumium screws to hold up body panels?
Need to revisit paneling for the tunnel sides. Local plastic supplier has 4x8 sheets of .060 HDPE for $188. Thinking of maybe cutting the side pieces out of this and then just zip tying them in a few spots to the frame tubes? Would be easier than welding tabs and using rivets. Any thoughts?
I was going to do carbon fiber panels but HDPE is light, durable, snow won’t stick to it and it would be much easier to work with. It would only be for the sides, around the header and flex pipes will have to be aluminum to handle the heat. Was originally thinking of using some .040 7075 sheet I have but snow sticks to aluminum no matter what you coat it with and it’s heavier than HDPE.
Nikolai
Played around with the HDPE tonight on the clutch side. Only made it as large as necessary to keep my boots out of the track. My plan for the all the tube work is to wrap it in UHMW tape after it’s painted to keep snow from sticking to it.
Anywho, started out with it in 2 pieces.
Quickly realized I could do it a lot cleaner in 1 piece and also run it up to the bearing plate.
It secured with 13 zip ties and plenty rigid with the zip ties pulled tight.
Initial thoughts.
- super easy to cut with tin snips
- lightweight, that piece is only 0.49 lbs w/ zip ties
- snow won’t stick to it
- easy to confirm to the tube work
- no need to cut and weld tabs or rivet aluminum pieces
I’m not dead set on using it. I just wanted to get a finished piece made to see what it weighed, what it looked like and if it would be stiff enough to keep a boot out.
Thoughts?
Initial thoughts.
Thoughts?
zx4ever
- Apr 14, 2011
- Northern BC canada
- 08 nytro ty4stroke customized
I would weld tabs and rivet it. With the amount of work you have put in this what’s another 1hr for a nice finished product. And hdpe is great I used it on my old tube frame tunnel and it held up great
Nikolai
I think if I did tabs & rivets I would use aluminum or carbon fiber panels so I could cut the amount of tabs in half. I still have to enclose the front around the track and headers as well so I may still end up with a once piece carbon insert. I need to get the motor and header installed and see how difficult that’s going to be.
YamaMTX
- Feb 7, 2009
- crosslake MN
- 2009 Yamaha nytro and polaris 600 rush
That is an awesome build!
Nikolai
I’ll get the motor in next and see what the front close off is going to look like. My other thought was to use plywood to make the shape of the enclosure with the front and sides all a single piece then make a fiberglass mold from the plywood for building a CF enclosure.
I do like the HDPE being a separate piece though because it gives good access to everything. Kinda nice being able to put the sled together and install the tunnel sides last.
Nikolai
Couple years ago I made a heat shield for the header that was just larger than the header. My plan at the time was to do carbon fiber for the rest.
Fast forward to now and I recut a larger piece. Fuel tank will cover the top of the tubes so snow can’t get trapped in between. The sheet is .040 7075 and weighs 1.12 lbs. I don’t want to put any holes in the tubes on this frame so I’ll weld tabs on and rivet it.
kinger
- Jan 17, 2005
- Clear Lake, IA
- www.piergenius.com
Looks sick all together but naked yet. Run with HPDE this year and see how it goes. My guess is the zip ties will freeze and crack, but won’t hurt to try it out and that is an easy thing to mod later. I would do carbon only if I could prove snow won’t stick to it.
Nikolai
I don’t think the zip ties will break. I used cheap ones for now but I have some really nice 50 lb zip ties I get from the aviation store that are a different type of plastic and have a metal clip. Easy enough to carry a couple extra zip ties out riding.
Only one way to find out though!
The frame will also just be painted, no powder coat, so modifications down the road will be easy.
Nikolai
Put the motor in to start working on the front tunnel block off. I forgot I had moved the engine back as far as possible to get the weight back. Clearance to the oil filter will be tight but I’ll make sure I am able to flex my block off plate out of the way when unscrewed so I can get the filter off.
Getting general idea of clearance and layout.
It’s tight to the starter and filter but on this build I wanted the motor moved back.
Getting the bends figured out. The main block off piece will be .040 7075 with a piece of HDPE riveted to the back to keep snow from building up. The upper piece the header pipes go through will be .040 2024 since I can put tight bends in that. The 7075 needs a big radius to prevent cracking.
Nikolai
Had to take the motor in and out a couple times to verify starter clearance with some practice pieces.
Couple practice bends first and then got the final piece bent up. I need to notch out for the jackshaft bearing carrier and weld some tabs to the frame in a couple spots to rivet it to.
I wanted to stick with as much tubing as possible and thin sheet metal to keep it light but it definitely would have been far easier to just make a .063 or .080 tunnel and build around that. I’ve got my work cut out for me to enclose around the chaincase and some other areas. Probably just end up using HDPE for it since it’s easy to work with and flexible.
Nikolai
Forgot how much time all the little tabs take. Lower tabs, made from .063 4130 plate. Incorporated skid plate mounts as well to save weight. Top 5mm hole is for the tunnel block off, lower hole will get a 6mm rivnut after the frame is painted. Should have the rest of the tabs done in a few days.
Was hoping to be under 0.25 lbs for all the skidplate tabs and under 0.25 lbs for the tunnel enclosure tabs.
Nikolai
Middle tabs done out of .063. Screws for now, final assembly will probably be solid rivets. Depends on if I powder coat the sheet or attach of a piece of HDPE to it. I don’t want to leave it bare aluminum to prevent snow build up.
Need to do a tab on each side at the top and then notch out for the bearing holder.
kinger
- Jan 17, 2005
- Clear Lake, IA
Will you be able to unscrew the oil filter, if not maybe that plate can be removable? I love the idea of moving it back, and keep forgetting the 3 banger has the oil filter back there. Its in the front on the apex. The use of HPDE is interesting, I hadn't thought of that. How much heavier is it then an equivalent piece of aluminum? I appreciate all the updates and details as I mentally plan my chassis build for my apex.
Nikolai
With the bottom two screws removed the plate should flex back far enough to remove the filter, that was the idea anyway, I’ll verify when I install the motor again after doing the top tabs.
HDPE is lighter given equal thicknesses but there is zero rigidity to thin HDPE so it works well in some places and not others. In areas with larger spans between supports the .040 aluminum is plenty rigid for the sake of blocking snow. I will either powder coat that front piece or rivet a piece or HDPE to the back.
- 222K
- 7K
- 122K
