Didn’t one of the guys have that valve come out of housing last year?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
I never heard that, it's a pressed together unit.Didn’t one of the guys have that valve come out of housing last year?
I orderd one today that hopefully warranty will cover. Damn thing is 150 bucks.
Yes. I will find it. Here is another with same thing you have going onI never heard that, it's a pressed together unit.
https://ty4stroke.com/threads/oil-leak.146222/
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Yes I've been talking to this fella.Yes. I will find it. Here is another with same thing you have going on
I thought it would Be good to have a thread just for the valve so people know what to look for.
Donedooinitwinder is guy who had his fall apart. Is in same thread few posts down. With pics.
I wonder if a Jacobson valve would flow enough? Could just rely on tether or get elaborate and use some kind of a switch to activate it. Most cars and trucks have something electronic to shut fuel off.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
The problem with roll over isn't just turning the machine off, it's the oil flowing out the vent into the intake and beyond.
The machine would have to be upside down for a while. But it could happen.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Yes I see your point for sure.Here is how it looks inside. Sounds like it's just pushed together. Joe a rollover valve such as 4strokesolutions Jacobson valve shuts oil flow off also.
I'm stuck. I don't know if I'm going to just run the valve and hope it doesn't leak again or run without a roll over valve and hope not to roll over
Hear ya. Would be nice to know what is failing in that valve. Odds are it won't happen again Joe. Would be more widespread if it was a design failure. So far it's just you and Jon we have heard from.Yes I see your point for sure.
I contacted him to see if he has one in mind.
http://fourstrokesolutionsllc.webs.com/
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
Can we put a lesser spring into that valve? Is it easily taken apart?
It must be pretty easy since donedooinit had his fall apart when removing the hose.This is one area to be real careful though. Phazer guy had the idea of using a PCV valve and it worked but one guy had his freeze and lost a engine. So could be real touchy.Can we put a lesser spring into that valve? Is it easily taken apart?
saskattakman
a friend of mines is leaking as well..seems like once sled was pulled out of storage he noticed it..was dripping out the bottom of belly pan and made a heck of a mess of the lower panel
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
I never seen this company before. Very coolI contacted him to see if he has one in mind.
- 52K
- 153K
