ViperBill
- Dec 14, 2014
- Linwood mn
- 14 viper rtx
Exactly but I hit a spuare bump about 18in talk about 60mph. Couldn’t believe it didn’t do more damage or cause a crash. The doo in front of me went end over end. Totaling his sled. I’ll take a broken suspension arm any day.Like this?
This is pathetic. My monoshock suspension in my apex held up better than this.
RTX
- Mar 31, 2005
- massachusetts / maine
- 2014 viper rtx
2006 apex rtx
Ya, i didnt hit anything like that. Just Normal/rough trail riding in maine.
fx-treme
- Jan 7, 2005
- 2014 SR VIPER LTX SE
Cannondale, I have a 2014 ltx Se and just broke the cross shaft. I am going to up date to the 2016 yamaha parts but wondering why the center shock axel is included in the new parts. Mine in fine just broke the cross shaft. Is this need to update the cross shaft. Thanks.Here is complete RR shaft. Stronger bigger design. Those bushings on end are same dimensions other than the flange is thinner. They also are machined rather than powdered metal like stockers. I would imagine the RTX LE is same thing. Didnt have one on hand to check so all I have are Cat part #'s
8408-051=Bolts 2 needed
3604-791=Bushing 2 needed
3604-711=Front Arm axle 1 needed
3604-798=Center Shock Axle steel 1 needed
These are what I believe are the equivalent Yamaha Parts
8KN-G7465-00-00 = FRONT ARM AXLE 1 NEEDED
8KN-RA1A0-00-00 = BOLTS 2 NEEDED
8KN-RA805-00-00 = BUSHING 2 NEEDED
8KN-RA729-00-00 = CENTER SHOCK AXLE STEEL 1 NEEDED
rbell14
Center shock axle is known to bend also. The upgrade is the race replica part and suggested to be replaced to avoid that issue in the future.
fx-treme
- Jan 7, 2005
Thanks I will look into replacing that as well.Center shock axle is known to bend also. The upgrade is the race replica part and suggested to be replaced to avoid that issue in the future.
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Has anyone actually replaced the steel bushing/collars due to wear? Working on a beefed up steel cross shaft design and debating just making the entire shaft the od of the bushing so its just one shaft and not a 3 piece design.
I have a cracked front arm on my 14 RTX (@ lower cross shaft), caught it before anything major failed luckily. Did anyone find out if the 16-17 front arm is a direct replacement for the 14-15 arm? It is considerably cheaper to purchase for some reason. If it is not I will probably just weld mine up and reinforce it to prevent a future problem.
Weld and reinforce. Geometry is different 16.5 up.I have a cracked front arm on my 14 RTX (@ lower cross shaft), caught it before anything major failed luckily. Did anyone find out if the 16-17 front arm is a direct replacement for the 14-15 arm? It is considerably cheaper to purchase for some reason. If it is not I will probably just weld mine up and reinforce it to prevent a future problem.
gpxsrx
- Dec 15, 2009
- way to many 2 strokes
My190 hurricane turbo2015 viper has been nothing but Steller 5000km, But this week had cross shaft failure I do have Bill's front spring installed. If you ride aggressively I would recommend replacing front cross shaft to the new beefier one part numbers listed in above thread by Cannondale27. wish I would have read this thread earlier. I was lucky enough to still ride home didn't break any speed records drove 50kmh the legal speed limit for trails here in Ontario. lol
rbell14
Are you saying the spring was a contributing factor to failure?
gpxsrx
- Dec 15, 2009
NOAre you saying the spring was a contributing factor to failure?
I hit a jump on trail landed hard on a mogul on the front of skid .
rbell14
Thanks for clarification. I did the same last year and I do have the upgraded race replica parts now.
I just got bills spring but have not installed it yet. Wanted to be sure I understood correctly.
hellflyer
- Dec 2, 2008
- Georgtown ONT. Canada
- 2020 sidewinder ltx se
I replaced my cross shaft last year and glad I did, my buddy and I hit a big rock on the trail and he bent his on a 600 and mine is ok. I also replaced the lower shock shaft this year, mine was bent almost 1/4".
gpxsrx
- Dec 15, 2009
The cross shafts seem to break in the same place flush with the edge of the bushing.
hellflyer
- Dec 2, 2008
Yes that's where the bolt ends also! So it's a bad design. Titanium shaft would be nice.
- 11K
