yamahaguy
Ride SAFE
- Apr 20, 2014
- 2015 Yamaha MTX LE with MPI
I like the theory also but just thinking out loud here. There's no way to apply equal brake pad pressure to both sides of the rotor if the caliper and rotor are both fixed Right? Just like on a car when the caliper pins rust or seized up the caliper is no longer floating causing one of the pads to drag overheating the rotor and uneven wear on pads. In the case of the Viper/Winder the rotor floats instead of the caliper That's why they wiggle back and forth a bit. Wish that bearing had a couple of set screws like the old Yamahas
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
The caliper has pistons on each side, the pistons on each side will equal the pressure
You want the rotor locked solid and applying pressure to hold the bearing.
ROCKERDAN
OCD Sledhead
- Oct 8, 2005
- Other
- '18 RTX 50th "Winder"
What happens when locking rotor, is you get a pulsation in lever. That is the downfall.
Dan
Dan
jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
You mean like the one I had a few hundred before the bearing took a crap? Lol. Mine was like a real nice vibration. I’m not talking The Beach Boys song “good vibrations”.What happens when locking rotor, is you get a pulsation in lever. That is the downfall.
Dan
jonlafon1
- Aug 18, 2014
2024 Catalyst RXC
I will be replacing bearing and guessing shaft on mine. Good early fall project. Will be interested in whatever you come up with. Thanks
The rotor does not have to float since even though it’s a junk Caliper it has 2 pistons. Also if you look at a mountain sled Cat for sure. The driveshaft has two big nuts. One for tightening and one to lock it. Seems to work for them.I would worry about side loading the INNER snap ring on the axle, and also the outer snap ring will get side loaded by these 3 screws. Also, now the brake rotor is not floating, It will play havoc on the lever feel.
Dan
SideHogger
- Apr 16, 2016
- upstate ny
- 2017 Ltx-Le Sidewinder
Any news on this?Been working on a potential idea to lock the inner bearing race to prevent the drive shaft from spinning inside the race. The ring has 3 tapped holes and would utilize 3 bolts which when tightened will press the brake rotor hub against the inner race. Once bolts are tight there would be a nut to lock it in place (not shown in my fit up photos below). To install the ring approximate 1/8" of material needs to be removed off the brake rotor hub so it will fit between the hub and outside snap ring. I used a grinder as that is the easiest method many will have acces ATTACH=full]146903[/ATTACH] View attachment 146904
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Going to mock up another concept this spring. Would like to get away from having to even modify the brake rotor if possible. Some have eluded to some sort of locking wedge to install inside the drive shaft so I'm going to experiment with that idea a little.
SideHogger
- Apr 16, 2016
- upstate ny
Awesome Travis. Thanks for reply.
Its to bad you cant get a bearing with a set screw locking collar like Yamaha does on that bearing. I am sure the seal and the way it goes together might be rethought but since everyone on the site is re-engineering everything.. go for it!
craigwsrx
- Feb 19, 2007
- Fenton Mi.
- 2017 Sidewinder 27,000 miles
2009 Nytro xtx 31,000 miles
2006 Attak 26,500 miles
2003 RX1 13,500 miles
2000 Mountain Max 14,000 miles
1998 SRX Mountain 17,000 miles
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
After 4 drive axles I believe I have cured mine. I turned axle down where it rides in bearing, welded axle up with hard rod, turned it down to spec, now have hard against hard instead of soft axle against hard bearing. 2500 miles so far and looking good.
GoFast4me
So you have had 4 spun bearings on the drive axle?
Along the way which solutions did you try to resolve this before your current solution?
Janne339
Yes, seen that too on mountain Cats!
craigwsrx
- Feb 19, 2007
- Fenton Mi.
1995 V Max 600
1979 SRX 440
1975 GPX 338
1973 GP 338
Originally I thought my problem was .0005-.0006 clearance between axle and bearing. Bought a axle from Black Diamond thinking it might be an after market build. When I got it it was a Cat axle also and I ate that one up. Also added TD tune so I think added horsepower puts more strain on drive train. Replaced another one just so I could ride, by this time I was getting good at replacing them so it wasn't a big deal. Finally decided to weld it up to give me a hard against hard surface. Like I said I now 2500 miles and so far so good. I'm not totally convinced yet but I will put more miles on to make sure. I will most likely ride another 1000 before I'm done the year so i'll see how it goes.
Buddy of mine welded his axle also 13 Turbo. Has been a good fix. No issues with bearing spinning anymore.Originally I thought my problem was .0005-.0006 clearance between axle and bearing. Bought a axle from Black Diamond thinking it might be an after market build. When I got it it was a Cat axle also and I ate that one up. Also added TD tune so I think added horsepower puts more strain on drive train. Replaced another one just so I could ride, by this time I was getting good at replacing them so it wasn't a big deal. Finally decided to weld it up to give me a hard against hard surface. Like I said I now 2500 miles and so far so good. I'm not totally convinced yet but I will put more miles on to make sure. I will most likely ride another 1000 before I'm done the year so i'll see how it goes.
- 6K
- 57K
