jonlafon1
- Aug 18, 2014
- 2022 Sidewinder LTX_SE
2024 Catalyst RXC
And yes it’s warranty. Just had mine done under warranty.Travis mentions in his video , that some are getting the shafts warrantied .
If you did , any advice you can offer , as I have been told it is a wear issue not unwarrantable .
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Thanks jonlafon1 for your reply .And yes it’s warranty. Just had mine done under warranty.
Anyone have names of dealers in Canada that has warrantied the drive shaft and bearings ??
Anyone get the cross shaft warrantied ? It looks like a cheap piece of aluminum .
RAMSOMAIR
My dilema is that I have the sled apart. The whole left side and suspension out. I would have to assemble all this as dealer said he doesn't want it in parts. (I understand to a degree). Then dealer pulls the suspension and everything I just had apart and re-assembled. Also pulls the chaincase apart and re-assembles it. Then I will have to pull it apart anyway to install new gear and put the oil I want in it. Meanwhile, my side panels and hood are laying on the floor with a snow shovel on top of it and the shop cat is sitting on my seat lol. I have a used axle with 600 miles which I got for $50 from a fellow TY'er which I just think I'll do myself. Its torn down this far already!! I have till Dec 1 to make up my mind.
JayM
- Oct 29, 2018
- Pickering, ON
- 2017 Sidewinder R-TX SE
The exact reason why I took care of mine myself lol
IH8CROWS
- Jan 19, 2009
- Wisconsin
- 11 Apex
16 Apex
Mine was warrantied Powersports1 in Wisconsin.
Took the parts to them.
They took pictures and sent to Yamaha. 2 days later said my stuff was on order. Picked up parts and put back together myself .
My first Driveshaft was warranted also. Cross Shaft also with the tunnel.
RAMSOMAIR
Yes, all is warranted, just not sure I want to take it to anyone.
Sly99
Worked on a 2017 high country 9000. Shaft also gone. Installed the new track and put it back together for another warranty work. Have another bop order coming.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
So Yamaha warrantied the drive axle ?Worked on a 2017 high country 9000. Shaft also gone. Installed the new track and put it back together for another warranty work. Have another bop order coming.
DMCTurbo
- Nov 12, 2005
- Val Caron, Ontario
- 2017 Sidewinder XTX LE 137
Yes they are replacing them. Mine was covered as were many others on here.So Yamaha warrantied the drive axle ?
Turboflash
- Mar 18, 2019
- Southern MN
If your dealer is telling you it's a "wear issue" he's BS-ing you. It is a DESIGN defect and is a warranty claim (if your sled is under warranty). The dealers know about it, have been briefed on it by Yamaha but secretly don't want to tell you that. Many are trying to stick together to put up a front that they don't know about it and haven't ever seen one. Again, that's BS.
Sledroll
- Dec 19, 2005
- Muskoka , Ontario
- 2022 SRX LE
2017 SW LTX LE
Is the bent cross shaft also warrantable ?If your dealer is telling you it's a "wear issue" he's BS-ing you. It is a DESIGN defect and is a warranty claim (if your sled is under warranty). The dealers know about it, have been briefed on it by Yamaha but secretly don't want to tell you that. Many are trying to stick together to put up a front that they don't know about it and haven't ever seen one. Again, that's BS.
YesIs the bent cross shaft also warrantable ?
Sly99
yes, i should have the sled in about a week. sled have 8400km.So Yamaha warrantied the drive axle ?
Turboflash
- Mar 18, 2019
- Southern MN
Cat guys say as of right now, they are being quoted Dec. 20 for new track shafts. Back ordered. Lots of guys waiting.
- 9K
- 7K
