Bigblue1
Just went through and re-greased bearing etc. BOP saver flat out does the trick. The shaft is as good as it has ever been. When not the BOP saver is not in, my bearing slides in and out easily so I guess I did it just in time last year.
Fast
- Sep 25, 2018
I thought Travis said the bolt is only good for 43ftlbsI guess when I did mine and come up with 65 ft lbs wasn’t wrong afterwards. New shaft and bearing .001” different when did all measurements. When I pull out we will see what end result is.
thanks Pan
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
- 2017 sidewinder ltx dx
2018 snoscoot
Bolts are 1/2" grade 8 and fine thread so should easily be good for 90 ft lbs according to my chart.
The wedge threads are not hardened so they will likely strip before the bolt fails.
Could you harden them or make them out of tool steel? That would help with higher torque values and save the jaws from deforming.
Hammer70
GRIPNRIP
- Sep 6, 2015
- Niagara, Ontario.
They can easily hold 90 ft lbsI thought Travis said the bolt is only good for 43ftlbs
hibshman25
Vendor
- Sep 25, 2005
- Lebanon, PA 17042
2018 snoscoot
If I make the jaws out of a hardened material then I feel like the tool will have more resistance itself to overcome. I have some harder wedges to experiment with when I get time.
Ok, it was just a thought.
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE
18 Winder LTX 50th
97 SX Vmax 600 (red)
I'm thinking a hardened steel saver might invite more problems. Guys will be torqueing it to 150 ft. lbs. on a shaft that's worn 10 thousandths to get a snug fit. This will cause the shaft to split and that will get ugly.
You will never split that shaft that easy...you would snap the head off the bolt first.
I'm glad you said something! Lol.You will never split that shaft that easy...you would snap the head off the bolt first.
Didn't want to be the first!
Right and if they can split that shaft, I would pay to see it done. lol
DennyTuna
- Jan 28, 2017
- Ohio
- 25 Winder LTX LE
18 Winder LTX 50th
This shaft is nothing special, if it was it wouldn't be that easy to wear out so fast. Never say never!
1nc 2000
Lifetime Member Tim
- Feb 26, 2010
- Marquette, MI
- Yamaha FX Nytro RTX SE
I had my sled in and asked them to check it but it would cost me way to much if there was not a problem
Easy to check. Lift rear of sled off ground, loosen up the track. Crawl under sled and grab driveshaft next to bearing from inside the tunnel and push up and down on it.
If its worn from spinning on shaft you will feel the play between the bearing and shaft.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
If cat would just tighten the tolerance expectations from the outsourced manufacturer the dam issue would be non existent!!!
I replaced a driveshaft on customer's sled a month ago and the fit had a slight interference!
I was hopeful that the shaft was actually updated and improved but I been through a couple more new shafts since and the fit is all over the map.
yamamarc
- Sep 29, 2013
- Massey Ontario
- 2019 zr9000 Ltd
I remember when you installed it you actually pulled the shaft out of your sled and tested it on a bench at different torque values!! So I'd say you torque it properly.I guess when I did mine and come up with 65 ft lbs wasn’t wrong afterwards. New shaft and bearing .001” different when did all measurements. When I pull out we will see what end result is.
thanks Pan
- 6K
- 58K
