eightpilot
- Mar 17, 2009
- Mosinee WI
- 2021 Thundercat
- Mosinee WI
Give it 3 ugga dugga's....... Problem solved
Note guys , not too much grease or never sieze , it will find its way out to the clutchs !!! been There !
2021 the shaft and bearing fittement has been addressedIs this going to be an issues with the 2021 sleds or did they start machining the shaft properly?
Are you Sure? I bet it's still not locked. Shaft expander would be great for peace of mind. Rather than finding out later.2021 the shaft and bearing fittement has been addressed
Yes it was mentioned on a live Q and A with Jarrett from yamaha Corp.Are you Sure? I bet it's still not locked. Shaft expander would be great for peace of mind. Rather than finding out later.
Even at room temperature, a new bearing is pretty stiff turning. I'm locking mine down and be done for the next 10,000 miles.
The last shaft I ordered beleive i end up with a updated shaftAre you Sure? I bet it's still not locked. Shaft expander would be great for peace of mind. Rather than finding out later.
No sight glass in chaincase! It's a grub screws to check levelAnything more on 2021 sleds having new shaft and bearing
Thanks Marc I noticed th sight glass just wondering if the 2021 needs wedgeNo sight glass in chaincase! It's a grub screws to check level
The question is have all old shafts been purged from supply line such that every 2021 got the new shaft?The last shaft I ordered beleive i end up with a updated shaft View attachment 156978 View attachment 156979
This shaft was .0015" oversized and required to warm bearing and cool shaft to install
