XP123
- Dec 25, 2016
- Chautauqua NY
- Sidewinder XTX LE 137
When the sled is moving at speed everything in the case should be getting plenty of oil. I can't see that hole making any difference.
krm
- Apr 22, 2016
- ny
The 21t gear i took out of my SW had no hole in it ,bushing looks good ,and has over 2200 miles on it .Put in a 22 for the added power .
stevewithOCD
Yamaha, Make me Come Back
- Jan 1, 2008
- Live CT Ride MAINE
- 900 R
2006 Apex RTX
So if one hole is good, four holes would be mo better.
Mike just cracked a joke...................i think!
Motorhead
- Apr 20, 2003
- Augusta, Maine
- 2017 SW LTX-LE
- Augusta ME
Funny maybe, but 4 would allow for mo oil passage.
KnappAttack
- Feb 19, 2004
- Welch MN
- 2023 Sidewinder LTX-LE
2017 Sidewinder LTX-LE
Correct, and at a min one if not two holes would always be upward to allow just a weee bit of oil to settle into the bushing in case someone decides to throw it in reverse and reverse out of somewhere after the machine has been sitting for a while when you really need the "oil to be there".
NYTurbo
Seen a Yamaha 21T today with 3 holes and none of them drilled through the bushing.
STAIN
- Feb 29, 2004
- Vermont
- 2022 SIDEWINDER LTX GT
- Vermont
I tried to drill a few holes in that gear tonight. I cant find a bit that will touch it.........
jaydaniels
- Dec 10, 2008
- Bedford NS Canada
- 2017 Sidewinder RTX
Yeah I’m sure they hardened. It baffles me why they are even there in the first place if the bushing isn’t drilled.I tried to drill a few holes in that gear tonight. I cant find a bit that will touch it.........
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
- 2017 sidewinder ltx-dx
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- 2015 Viper 270 hurricane,
- Wisconsin
I will have to check mine it’s been popping out of gear the last 100 miles.
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
Ya. I would say it's shot! Sleeping out of forward gear ?I will have to check mine it’s been popping out of gear the last 100 miles.
ClutchMaster
HUGE Member
- Jan 18, 2016
- tomahawk
- Wisconsin
Yes just started doing it so I need to take a look at it.Ya. I would say it's shot! Sleeping out of forward gear ?
Joe ltx-le
- Mar 26, 2015
- Beaverbank-ns
There's nothing to it. Pop the cover off and take the gears and chain out. If you haven't done it before just pay ateention to where all the shim washers goYes just started doing it so I need to take a look at it.
Pstn head
Ya it's done
Jafo1970
This is the gear off my 17. 5300 miles.
There is no hole in my gear. Not just the bushing the gear doesn't even have a hole.
The bush fits very loose on the shaft it looks pretty bad
Exactly why I tell everyone to replace that bushing, its cheap. Cheaper than the possibility of skipping out of gear and trashing your 2 top gears and ruining your day. Back in 2012/2013 was good for 2500 miles, now its closer to 5000. Super easy to do if you already have cover off chaincase. Bushing can be hard to find separate but you can buy the cheapest 2012 top gear from cat for around $20. Press bushing out and install in your existing gear. There not that tight in there either.
- 8K
- 39K
- 14K
